The CPU is i9-13900k and the OS is Ubuntu 20.04 LTS.
The DP port is unavailable and monitor resolution cannot be adjusted because the CPU internal graphics card is not recognized.
It's a development PC, so the build setting is set to 20.04. Therefore, you cannot upgrade the OS to 22.04. Is there a solution other than this?
Hello JunGrammer,
To better assist you, please provide us with the following information:
- Is this issue present since day one?
- Have you contacted Ubuntu Support for recommendations?
- Check if the DP port issue persists on the BIOS menu.
- Update your kernel version to the latest version available, 5.19.0.
- Install the latest Intel software to enable general-purpose GPU capabilities for Ubuntu* 22.04. Check this website for the documentation and instructions about this process.
Best regards
Jean O.
Hello JunGrammer,
We hope you are doing fine.
Jean O.
Hello JunGrammer,
Best regards.
Jean O.
