Hello
I will connect 3 screen on my PC : one in VGA, one in HDMI and the screen of my laptop
When I plug the screen inHMDI to my laptop it's OK .
But when i add the screen in vga, the HDMI screen turns black and only the screen in VGA and the screen of the laptop work.
How to solve this problem ?
Theoretically your processor supports 3 monitors according to https://ark.intel.com/products/72164/Intel-Core-i5-3230M-Processor-3M-Cache-up-to-3_20-GHz-rPGA Intel® Core™ i5-3230M Processor (3M Cache, up to 3.20 GHz) rPGA Product Specifications
At first check out https://www.intel.com/content/www/us/en/support/articles/000005556/graphics-drivers.html Frequently Asked Questions About Configuring Three Displays
Try drivers from this list https://downloadcenter.intel.com/product/81499/Intel-HD-Graphics-4000 Downloads for Intel® HD Graphics 4000
Select OS from right pull-down menu. Hit "show more".
To bypass message "best driver is already installed", "customized computer manufacturer driver" or "computer is not validated" install driver via have disk method as described at:
https://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
MSI does not offer Windows 10 support for your rig https://www.msi.com/Laptop/support/GE60_0ND Support For GE60 0ND | Laptops - The best gaming laptop provider | MSI Global
Also NVIDIA Optimus technology can make things more complicated.
Try to find a setting in BIOS where you can control monitors.
Otherwise search for further help at https://www.msi.com/page/forum MSI FORUM | MSI Global
I think that when I connect the screen with the vga port this disconnects the screen with the hdmi port.
And i don't know why...
Hello pmlssp,
I understand that you are having problems with connecting 2 extra monitors to the laptop.
Regarding this, To better assist you with your request, I will need to check some information about your computer. Please follow these steps:
1. In the keyboard, press WinLogo key + R.
2. In the Run box please type dxdiag and hit Enter.
3. Click on Save All Information (save it in your desktop).
4. Attach the report to this thread.
David V
Hello
and thank you for helping me.
I have attached the requested file.
Currently I connected two extra monitor to my laptop but with this configuration the screen of my laptop does not work.
Finally, this solution suits me perfectly the screen of my laptop being of poor quality (black pixel).
if with the diagnostic file the solution is obvious then tell me but if it is more complicated do not bother to find a solution that i'm not sure to use.
a thousand times thank you
Pascale
Hello pmlssp,
Thank you for your response,
Upon review of the information everything seems to be OK. Now, regarding the connection that you are making. Have you tried using a different HDMI cable? Or perhaps connecting the HDMI first and then the VGA?
Make sure to open "Graphics Properties" and select how you would like to configure the multiple displays from there, refer to the screenshot attached for more information.
David V
Thank for you answer.
I have already done this operation to plug my two extra monitors and it's work very well
The problem is that the screen of my laptop is not detected as the third screen.
I thought that with my configuration I could use 3 independent screens two external screens plus my laptop.
But with the "panel of configuration graphique HD Intel" I can not do it, only my two external screens are detected.
Pascale
Hello pmlssp,
Here are a few steps that I would like you to follow in order to attempt and fix the problem you are currently experiencing:
https://www.intel.com/content/www/us/en/support/articles/000025671/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000025671/graphics-drivers.html
These steps must be followed in order to activate a three-display setup.
David V
Hello pmlssp,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
Hello pmlssp,
Regarding the issue that you are currently experiencing it could be due to the way you have the monitors configured. For example, here are different configurations that are supported for multi-monitor:
https://www.intel.com/content/www/us/en/support/articles/000025673/graphics-drivers.html https://www.intel.com/content/www/us/en/support/articles/000025673/graphics-drivers.html
In order to be able to use the current configuration the built-in display must be connected with an embedded display port. I would advise you to check with the computer manufacturer to see if the built-in display is using it or not. The graphics controller supports it but the computer does not seem to have the minimum requirements for a 3-monitor configuration.
For further help, please contact your manufacturer:
https://www.msi.com/support https://www.msi.com/support
Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there.
David V
Wow, does it take this long a conversation to say that this particular laptop does not support the VGA and HDMI connectors being used simultaneously?
Hello David,
I will look on the site of msi if it is possible with my laptop.
thank you for all your help on my problem, I will stay with 2 screens
Pascale
Hello pmlssp,
I apologize for any inconvenience and thank you for your understanding.
If there is anything else you may need do not hesitate to reply for further help.
David V
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
