22667 Discussions
Problem with HEVC 4K 8-bit playback with Atom x7-Z8700 Cherry Trail
PJ
New User
I have Surface 3 (Windows 10 x64) with the latest Graphic driver: 08/04/2015,10.18.15.4248
But when I play an HEVC 8-bit 4K video with Atom x7-Z8700, I get square artifacts:
http://imgbox.com/3b2aIiqh imgbox - fast, simple image host
Please solve the driver problem
Bryce__Intel
Hi there PJay
PLease try the following driver.
https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Note that it may be expected that users will see performance or artifacts when playing content that is not
within the CHV\BSW HW codec support specs. See the info below:
/message/388818# 388818 https://communities.intel.com/message/388818# 388818
User reported on CHV:
  1. H.265 8bit 4K 59fps 78.2Mbps: Observe corrupted colors. This is expected behavior given the support spec below.
SteppingSupported Decode FormatNotesCHV\BSW A-stepHybrid HEVC 8bit DecodingNo support for Hybrid HEVC 10bit Decoding.
Up to 4096x2160@30fps bitrate@25MbpsCHV\BSW B-stepFixed Function HEVC 8bit DecodingNo support for FF HEVC 10bit Decoding.
From the CHV spec, for Decode H.265 Profile and Level support:
Main Profile and Level 5
Bitrate up to 25Mbps
Resolution 3840x2160@32fps
Resolution 4096x2160@30fps
MSchm21
Valued Contributor I
10.18.15.4248 is outdated as hell, update your driver and try again before reporting an issue because it possibly is fixed already in newer drivers.
PJ
New User
Since I know, there's no new driver for Cherry Trail.
Hi PJay,
I checked the specs of your Microsoft® Surface-3 and I found the maximum resolution of the Surface-3 is 1920 x 1280; it's possible that this issue comes up because 4k only supported by 6 generations processors.
Hellen.
PJ
New User
Thanks for reply,
It doesn't relate to the screen resolution. It can output 4K easily via Display Port though:
http://www.notebookcheck.net/Microsoft-Surface-3-Tablet-Convertible-Review.141116.0.html Microsoft Surface 3 Tablet/Convertible Review - NotebookCheck.net Reviews
It also fully supports HEVC format up to 4K resolution:
http://www.notebookcheck.net/fileadmin/Notebooks/Microsoft/Surface_3/dxva.jpg http://www.notebookcheck.net/fileadmin/Notebooks/Microsoft/Surface_3/dxva.jpg
Hi PJay,
Please check, if in this link form Microsoft® is there any driver that could help you to fix this issue.
https://www.microsoft.com/surface/en-us/support/install-update-activate/download-drivers-and-firmware-for-surface?os=windows-10 https://www.microsoft.com/surface/en-us/support/install-update-activate/download-drivers-and-firmware-for-surface?os=windows-10
It is important to mention that we sell our Intel chipsets and processors to third party manufacturers as Microsoft® and they design their own computers with their own features, settings and capabilities.
For that reason they design their own drivers, to meet the exact specifications on their computers.
Hellen.
Hi PJay,
Let me investigate more about this issue, and as soon I get a solution I would let you know the answered.
Hellen.
PJ
New User
CCris2
New Contributor II
What player you use ? Not all players are able to play correctly 4k content.
You can try use this player : http://www.videohelp.com/software/PotPlayer PotPlayer 1.6.60136 / 1.6.60286 Beta - Download
I use this on an i7 6700k and it playes nicely, and it has option to use hardware or software codecs.
PJ
New User
Windows 10's media players, MPC-HC, PotPlayer, DXVA Checker...
i7 6700K is Skylake and it has different driver but Atom x7-Z8700 is Cherry Trail and I couldn't still find a newer working graphic driver for Surface 3
CCris2
New Contributor II
The drivers for Surface 3 are provided by microsoft: https://www.microsoft.com/en-us/download/details.aspx?id=38826 Download Surface Pro 3 from Official Microsoft Download Center
and they are dated 4/25/2016
PJ
New User
It's Surface 3 not Surface Pro 3
https://www.microsoft.com/en-us/download/details.aspx?id=49040 Download Surface 3 Wi-Fi from Official Microsoft Download Center
CCris2
New Contributor II
Ok, you didn't mention what type was
You have those drivers ?
PJ
New User
Surface 3 Pro has Core i5 Haswell not Atom Cherry Trail.
I got the driver from here (also said in the first post) :
Hi PJay,
I apologize; this is the answer I could get.
Cherry Trail supports HEVC hardware decoding up to 3840x2160 resolutions.
Supported media detailed, page 130: http://www.intel.com/content/www/us/en/processors/atom/atom-z8000-datasheet-vol-1.html http://www.intel.com/content/www/us/en/processors/atom/atom-z8000-datasheet-vol-1.html
Surface 3 drivers are customized by Microsoft, in regards to your issue my recommendation is to contact Microsoft and request to review the Graphics driver issue on your device.
Hellen.
CCris2
New Contributor II
Hi Hellen,
The problem is that the HEVC/H265 codec is not available in encode/decode page (on skylake i7 6700k is the same problem), in the program he is using.
It can be selected only the software codecs ...
When I tried to run a lower then 4k video with Quick Sync selected as H265 decoder the PotPlayer went on software mode ... It worked in hardware mode only when I used DXVA.
When I played H264 movies in 4k they worked with Quick Sync.
PJ
New User
I use DXVA2 native.
As you see in the screenshot of the first post, Z8700 can play HEVC 4k 8-bit in hardware mode but with artifacts/incorrect block colors.
CCris2
New Contributor II
When you play on PotPlayer you get same artifacts ?
PJ
New User
Yes, it's not player/decoder problem.
CCris2
New Contributor II
I see.
I just hope the next driver will fix this thing also as there are lots of problems reported.
