22668 Discussions
Problem with HEVC 4K 8-bit playback with Atom x7-Z8700 Cherry Trail
PJ
New User
I have Surface 3 (Windows 10 x64) with the latest Graphic driver: 08/04/2015,10.18.15.4248
But when I play an HEVC 8-bit 4K video with Atom x7-Z8700, I get square artifacts:
http://imgbox.com/3b2aIiqh imgbox - fast, simple image host
Please solve the driver problem
Bryce__Intel
Hi there PJay
PLease try the following driver.
https://downloadcenter.intel.com/download/26347/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Note that it may be expected that users will see performance or artifacts when playing content that is not
within the CHV\BSW HW codec support specs. See the info below:
/message/388818# 388818 https://communities.intel.com/message/388818# 388818
User reported on CHV:
  1. H.265 8bit 4K 59fps 78.2Mbps: Observe corrupted colors. This is expected behavior given the support spec below.
SteppingSupported Decode FormatNotesCHV\BSW A-stepHybrid HEVC 8bit DecodingNo support for Hybrid HEVC 10bit Decoding.
Up to 4096x2160@30fps bitrate@25MbpsCHV\BSW B-stepFixed Function HEVC 8bit DecodingNo support for FF HEVC 10bit Decoding.
From the CHV spec, for Decode H.265 Profile and Level support:
Main Profile and Level 5
Bitrate up to 25Mbps
Resolution 3840x2160@32fps
Resolution 4096x2160@30fps
CCris2
New Contributor II
Good
Who should know better if there is something wrong with the driver or the codecs if not the ones that created the OS which is on a product manufactured by them
CCris2
New Contributor II
I forgot to ask you what is the message when you try to install the last driver ?
Hi Pjay,
I hope they could help you, please let me know, if there is anything else you need.
Hellen.
PJ
New User
@Ronin Not sure, something like not compatible...
Seems Microsoft doesn't wanna fix it, wasted $600 on a garbage device with no support.
Shouldn't expect more from Microsoft...
CCris2
New Contributor II
Hi PJay,
Try to install this driver https://downloadcenter.intel.com/download/25749/Intel-Beta-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40- Download Intel® Beta Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.40]
Bryce__Intel
Hi
I confirmed your chipset supports 4k, though there's nuances to robustness since it's a low power processor. Could you provide a link to a clip that fails for you? I'll track down a CHT Surface 3 here and push this into investigation.
Bryce__Intel
Hi there PJay
