I have an intel i5 11 gen with iris xe graphic card, so I'm facing issues regarding fps in GTA 5,even at the lowest resolution I'm getting fps below 20
Hello yuvraj_shekhawat,
I am sorry you are having issues with your Intel® Iris® Xe Graphics. I will be glad to assist you.
Please provide the following information:
- Was the video game working fine before? If that is the case, was there any hardware change or driver/OS update before the issue started?
 - How are you measuring the FPS?
 - Does the issue happen with other games?
As well, please perform the following steps:
- Make sure you have the latest game updates and patches.
 - Perform a clean installation of the latest graphic driver version 31.0.101.4032 https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html
 - Verify you have the latest Windows updates installed.
Steven G.
Did all the above steps but getting low fps still. As earlier I was getting 45 fps at medium settings in valorant but now getting 27 fps. I had run all the tests and the result was positive and also updated my driver. The temp while playing the game was 70 c and graphic usage was 90%.
Many thanks for your response.
I understand the laptop it is not performing as expected and I will be glad to assist you with this. In order to do so, could you please provide the information requested and perform the steps recommended in my previous reply?
Steven G.
We would like to know if you were you able to check my previous response.
Steven G.
NO, still facing the same issue even though it worsened now after your updates. This problem is from initially when I purchased my laptop I'm not getting the desired result
Please confirm this information:
As well, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Many thanks for your detailed response.
Please follow the recommendations below:
- Update your BIOS to the latest version (1.20) released by Dell (https://www.dell.com/support/home/en-us/product-support/product/inspiron-15-3511-laptop/drivers).
 - Download and install the Intel® Processor Diagnostic Tool (https://www.intel.com/content/www/us/en/download/15951/19792/intel-processor-diagnostic-tool.html?) to run a test on the processor.
 - Stop any other heavy workload programs running in the background while playing, if any.
 - With MSI Afterburner or any other third-party software of your preference, measure the usage and temperature of both CPU and RAM while in-game. This will help us to determine if there is any load/overheating issue causing the drop in FPS.
 - Try repairing the installations:
- In Steam, you can do so by opening the Library tab.
 - Right-click the game.
 - Click Properties.
 - Once in the Properties window, click the Local Files tab, and then click Verify Integrity of Game Files.
Please let me know the outcome of each of the previous recommendations.
Steven G.
Many thanks for confirming that information.
I would like to replicate the issue on a similar environment. In order to do so, kindly provide the SSU report again now that everything is fully updated.
Here are the instructions again: Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Thank you for the report.
I will be working on this case and as soon as I have an update, I will let you know.
Steven G.
Please try the following steps and let me know of the outcome for each of them:
- Try configuring the graphics settings as recommended here: https://gameplay.intel.com/games/grand-theft-auto-v (make sure to expand the 11th Generation Intel Core i5 Processors and select your processor to check the recommended settings).
 - Is the same issue happening when connected to AC power? Check that you have maximum power settings, as this is a laptop and performance may drop to save energy.
Steven G.
We would like to know if you were you able to check the previous post.
Steven G.
Yes, I checked your previous post and the settings for GTA 5 but the problem is that my game is giving 5-8fps with those recommended settings. I played it with minimum settings lower than those recommended in that section. I checked all other options like power settings and my pc performance.
I will keep working on this. Once I get an update, I will post back here.
Steven G.
Many thanks for your patience.
Based on the steps performed, it is possible there is a hardware issue, since your system should be running these games fine, and this is not happening. I highly recommend you ensuring the steps in this article (https://www.intel.com/content/www/us/en/support/articles/000030302.html) are followed, which most of them were during our interaction.
Our best recommendation is to contact Dell due to a possible hardware issue and for further assistance/information.
Steven G.
