22660 Discusiones
Problems with white glich in games
BrunoMIljan
Principiante
2.250 Vistas
Some games plays nice some i cant play bacouse this white glow glich
simular theme: https://community.intel.com/t5/Graphics/In-multiple-games-I-get-this-awful-white-glow-with-dark-pixels/td-p/1234751?profile.language=en&countrylabel=Mexico
my system data is in a.txt file down below
UPDATE: when i delete graphic driver image is good, i tryed to update driver but no luck
Someone help pls 😞
0 kudos
7 Respuestas
Reps
Principiante
2.219 Vistas
Your driver is outdated, install the Intel® Driver & Support Assistant restart your PC and run the program, it should give you option to download the latest Intel graphics driver for your system.
Hope this helps.
BrunoMIljan
Principiante
2.212 Vistas
hello i update it and i still have same issue
Reps
Principiante
2.210 Vistas
Can you run another SSU scan and attach the results here?
BrunoMIljan
Principiante
2.198 Vistas
Oky
Steven_Intel
Moderador
2.159 Vistas
Hello BrunoMIljan,
In order to better assist you, please provide the following information:
  • Was there any hardware upgrade or drivers/OS update before the issue started?
  • Is the issue happening in multiple games? Please specify which.
  • Is the issue happening on an external monitor or on the laptop's screen?
As well, please perform a clean installation of the graphics driver (https://www.intel.com/content/www/us/en/support/articles/000057389.html). You can download the driver here(https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html).
If the issue persists, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
Moderador
2.133 Vistas
Steven G.
Steven_Intel
Moderador
2.125 Vistas
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
Responder
