23849 Discussions
Qt-based application crashing when using OpenGL
PBern14
Hi similar to (https://forums.intel.com/s/question/0D50P0000490HYmSAM/qtbased-applications-working-with-opengl-were-broken-after-driver-update?language=en_US), we have a Qt application that crashes when opening simple QDialog when the application is using OpenGL.
The machine is an HP laptop with the following processor: Intel Core i7-6600U @ 2.60GHz
Running Windows 10 x64
Intel HD Graphics 520
There is a driver update in the previous case (above) that is not compatible with this machine.
The question is if there is another one that would be compatible,
Abigail_G_Intel
Hello PBern14,
Thank you for posting on the Intel Communities.
In fact, we have newer driver versions for the Intel® HD Graphics 520 than the one provided on that thread. You will find the downloads available in the following link:
https://downloadcenter.intel.com/download/28816/Intel-Graphics-Windows-10-DCH-Drivers?product=88355
Note: For laptops or other OEM computers (Original Equipment Manufacturers) we recommend to get the drivers available at the OEM website since those drivers are customized by your manufacturer (HP*), adding or removing features according to the specific computer model needs and to have the best performance for it.
You can look for your computer drivers and downloads available in this link:
https://support.hp.com/us-en/drivers
I hope you find this information helpful.
Abigail G
Under Contract to Intel Corporation.
Abigail_G_Intel
Hello PBern14,
I would like to know if the information provided was helpful?
Please let me know if you need further assistance.
Abigail G
PBern14
Hi Abigail,
Yes, I believe the answer was accurate and helpful. However, since the machine is an HP, we reached to them and they are unwilling to fix their driver at this time. 😞
Patrick
Abigail_G_Intel
Hello PBern14,
In this case, our recommendation would be to test with the generic drivers provided above.
Abigail G
Abigail_G_Intel
Hello PBern14,
Since you have mentioned that the response was helpful to address your request and that you contacted HP® for further support we are going to close this inquiry, if you have further questions, please post a new question.
Abigail G
