22684 Discussions
Rainbow Six Siege - Frame pacing issues
Yuukiya
Hi, I have observed frame pacing issues with Rainbow Six Siege (both DX11 and Vulkan)
When frame rates are unlocked issue is happening. Frames rates are high but its not smooth.
Capping frames doesn't solve it, only the in game vsync solve the issue.
Kindly please relay this issue to the driver team.
Intel Arc A770 LE
Driver used: 31.0.101.4369
Hugo_Intel
Hello Yuukiya
Thank you for posting on the Intel Communities. I am sorry you are experiencing frame pacing issues with your Intel® Arc™ A770 Graphics while playing Rainbow Six Siege.
Please share with us the following information to assist t with this issue:
  • Share a short video showing the issue.
  • Share a screenshot of the in-game graphics settings configured.
  • Is Resizable BAR enabled on your system?
  • How much fps do you get when V-Sync is enabled on the system?
  • Create a log file with the Intel® System Support Utility and attach it to your response to get more information on the hardware configurations.
Hugo O.
Yuukiya
Thanks for the reply. Please see below for more info.
- I do not have.
- see attached.
- yes
- never goes down 144 fps.
- I do not have this software installed. Willa Dxdiag suffice? Please see attached
Hugo_Intel
Hello Yuukiya
If you could record and share the video showing this issue it will be better so we can better understand the outcome that you are looking for as well as the behavior that you are experiencing. As for the Intel® System Support Utility software the link is in the previous, follow the instructions to download, install and create the log file that we need you to attach.
  • I see that you get 144fps and the issue does not happen when V-syn is enabled, Doesn't this work as a solution for the issue? How much fps do you get when V-Sync is not enabled?
  • How is frame pacing being measured and what is the frame time that you are experiencing?
Hugo O.
Jean_Intel
Hello Yuukiya,
We hope you are doing fine.
Jean O.
Hugo_Intel
Hello Yuukiya
We want to let you know that we are working closely with the game developer to improve the performance of this game and updates will be released soon from both the side, as a game update and driver update, there is no estimated time for the update to be released but it should be soon.
Hugo O.
Hugo_Intel
Hello Yuukiya
Since there are not further questions related to this topic we will be closing this thread and will no longer be monitored. feel free to open a new topic if you need further assistance.
Hugo O.
