hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
21988 討論
Regarding Intel's i5 11400 UHD 730 iGPU Issue
Sadaf
初學者
3,977 檢視
Recently I have purchased the intel i5 11400 and was planning to run some low spec game like Valorant on UHD 730. But after running that game, there's so much lagging and stuttering which made this game unplayable. I have installed the latest graphics drives and kept all other drivers up to date but still no improvement.
標籤 (2)
0 積分
4 回應
AlHill
超級使用者
3,975 檢視
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
Sadaf
初學者
3,974 檢視
Here's the attachment which you've asked for.
AndrewG_Intel
員工
3,927 檢視
Hello @Sadaf
We understand that you have opened an internal Web Ticket with us regarding the same environment and same issues so we will continue to help you through that channel now. We will therefore close this community case in order to avoid duplication of efforts. Thank you.
Andrew G.
Asystole
初學者
3,659 檢視
Are there any fix? I'm having these issue. I can't play any game without sudden drop of fps to 1.
回覆
