I tried 7 different version of the intel driver and none of them worked. In every of them, after a reboot, I get a blinking screen, artifacts like rosa pixels, gray bands and so on. However, this problem only show up on Windows. On the Fedora 42 install, everything just works.
However, since Windows does not work correctly, i cannot do my work on Visual Studio. If you could solve the problem it would be great.
Some details:
CPU: Core Ultra 9 185H
RAM: 32GB DDR5 5600MHz
GPU 1: Intel Arc Graphics
GPU 2: Nvidia RTX 4070 Laptop (Optimus)
Screen: LFP
Not applicable to external since they are linked to the Nvidia GPU
Seen on AC and battery
Resolution: 2.8K 16:10 varying between 25-120Hz
HDR: ON
Model: MSI Stealth AI 14 A1V
Software used: None, just rebooting
Install and reboot.
Video of the failure: https://photos.app.goo.gl/PZiRFAkJTzHidJQD6
Please note that in this video, it was the first issue encountered. Since, random artifacts can bee seen.
I give you the event viewer exports as attachments.
I started installing drivers around 5:40 PM.
What i tried:
- Clean install
- Clean install of the official MSI drivers
- Driver Rollbacks
What I don't want to do: Windows clean install
Thank you in advance
Thank you for taking the time to try to solve my issue.
Here is the final word today, I updated to the Graphics driver 32.0.101.6874 and everything works properly.
This issue is solved.
Best regards
Did you: download DDU uninstaller? and reboot in safe mode: to run it? and Waite and reboot and reload intel drivers?
No i can't try this either. The driver still crashes in safe mode, rendering the computer unusable.
Hello Xabi08,
thank you for reaching out to our communities. I understand that you're reporting artifacts on the systme that you are currently using.
However, to further investigate, I would need to acquire your System Support Utility Log.
To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*.
Robbie R.
Hello Xabi08,
Thank you for providing the SSU log file. To further investigate the potential causes of this issue, I would appreciate more information. Please check and share the following:
1) Does the issue occur within the BIOS setup?
- If the problem also appears in the BIOS setup, I strongly recommend reaching out to your system manufacturer's support team for assistance with the following:
- This might help resolve the issue, as there is a newer BIOS firmware available (released January 2025).
- Update the graphics drivers using the latest OEM drivers (NVIDIA Graphics Driver and Intel Graphics Driver). Although OEM drivers may be older than your current ones, they are customized specifically for your system device.
2) While working with your OEM support team, please seek assistance regarding the "huge artifacts" observed, if they are not resolved by the BIOS update.
Please keep me updated on the progress.
JeanetteC.
Thank you for your response.
My BIOS is already up to date since it is the first thing i did once receiving the PC.
This problem does not appear inside the graphical BIOS. It only appears on Windows. Every driver is already up to date as I check this every week.
Currently, I had to deactivate the iGPU in order to have a usable screen.
I dug in some existing docs that were a bit hidden and found out that it may be a problem related to MSI True Colors. I will try to do a clean install of both intel drivers and MSI True Colors as detailed here:
https://storage-asset.msi.com/global/picture/faq/10017191@2021-1028-0214-352106@kb_05206-en.pdf
I found out this thread about true colors.
I think I will just uninstall it as it serves no particular purposes.
Hello Xabi08,
I'm glad to know that you have updated your BIOS to the latest Version. However, since the issue still persists and your system only works with disabling the iGPU, it seems that at this point, the best course of action would be to reach out to MSI for further assistance.
With that being said, please do keep us updated and with what they said.
Robbie R.
Hello Xabi08,
Robbie R.
Hello Xabi08,
I hope you had the opportunity to review the information I posted. At your earliest convenience, please let me know so we can determine the best course of action to resolve this matter efficiently.
Archie D.
Hello Xabi08,
Archie D.
Best regards
