22680 討論
Screen-tearing with Haswell 4600
JSpaa
初學者
7,686 檢視
When playing flash movies, for example from youtube, i get screen-tearing.
Config:
video: i7-4770K onboard video adapter: intel hd 4600
os: windows 8
driver: 918103186
driver config: enabled vertical sync ("on")
motherboard: asus maximus vi formula
monitor config: clone-mode
0 積分
27 回應
Kevin_M_Intel
員工
4,785 檢視
Hello jeroompje,
Based on your description, I recommend you doing the following steps:
  1. Clear the CMOS on your computer by removing the batter for about 20-30 minutes.
  2. Download and install our latest driver at the following link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22842&lang=eng&OSVersion=Windows%207%20(64-bit)*&DownloadType=%0A%09%09%09%09%09%09%09Drivers%0A%09%09%09%09%09%09
  1. Test the computer with single display.
If issue persist please post your dxdiag report here.
JSpaa
初學者
4,785 檢視
cleared cmos and installed latest available driver.
still tearing.
with one monitor no tearing.
but i use 2 monitors in clone.
attached dxdiag.
hope intel can solve the problem.
Jerome.
System Information
Time of this report: 9/7/2013, 10:32:41
Machine name: PC
Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.130531-1504)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: ASUS
System Model: All Series
BIOS: 0714
Processor: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz (8 CPUs), ~3.5GHz
Memory: 16384MB RAM
Available OS Memory: 15296MB RAM
Page File: 1647MB used, 13647MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: The file RTKVHD64.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Intel(R) HD Graphics 4600
Manufacturer: Intel Corporation
Chip type: Intel(R) HD Graphics Family
DAC type: Internal
Device Type: Full Device
Device Key: Enum\PCI\VEN_8086&DEV_0412&SUBSYS_85341043&REV_06
Display Memory: 1792 MB
Dedicated Memory: 992 MB
Shared Memory: 800 MB
Current Mode: 1680 x 1050 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: SAMSUNG
Monitor Id: SAM090B
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HDMI
Monitor Name: SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)
Monitor Model: SyncMaster
Monitor Id: SAM03E5
Native Mode: 1680 x 1050(p) (59.883Hz)
Output Type: DVI
Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32
Driver File Version: 9.18.0010.3186 (English)
Driver Version: 9.18.10.3186
DDI Version: 11.1
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: Thread
Driver Attributes: Final Retail
Driver Date/Size: 8/11/2013 15:26:26, 8645120 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4752-11CF-817F-3EA5BBC2C435}
Vendor ID: 0x8086
Device ID: 0x0412
SubSys ID: 0x85341043
Revision ID: 0x0006
Driver Strong Name: oem8.inf:5f63e534dd898f5e:iHSWD_w8:9.18.10.3186:pci\ven_8086&dev_0412
Rank Of Driver: 00E02001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
DXVA2 Modes: DXVA2_ModeMPEG2_VLD DXVA2_ModeMPEG2_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeVC1_IDCT DXVA2_ModeH264_VLD_NoFGT
Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
{BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2...
JSpaa
初學者
4,785 檢視
Further help not available at Intel?
Kevin_M_Intel
員工
4,785 檢視
Hello jeroompje,
Based on your dxdiag report you are using another driver version not from Intel®. Please try this driver:
In case that issue persists, I recommend you updating the Bios in your motherboard.
JSpaa
初學者
4,785 檢視
with your advised driver and latest bios of motherboard problem still exists.
btw, i'm an it pro, not an end-user.
Kevin_M_Intel
員工
4,785 檢視
Hi jeroompje,
I have tested the driver from our side using different systems with a graphics controller HD 4600 and I was not able to replicate the issue. At this point, I recommend you trying with a fresh installation of the operating system and also testing another processor with the same graphics controller.
We came up with a new driver last week and I am not sure if you have tried. Just in case here you have the link:
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23106&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23106&lang=eng&OSVersion=Windows%208%2C%2064-bit*&DownloadType=Drivers
JSpaa
初學者
4,785 檢視
Kevin,
i did a clean install of windows 8 with intel graphics driver 9.18.10.3257
same results.
i'm using the intel i7-4770k proc.
not able to test on other haswell procs.
the issue is windows related and not haswell or intel specific:
- it occurs with windows 7 and 8
- with haswell, sandybridge and older chipsets/cpu's
- it occurs with build-in intel video graphics and discrete ati video boards.
in all those instances the issue is with 2 displays in clone-mode: monitor connected on vga or dvi and tv connected by hdmi.
when not in clone-mode, the issue disappears...
Kevin,
how to tackle it definitive?
Kevin_M_Intel
員工
4,785 檢視
Hi jeroompje & Isak,
I would like just to confirm with you if you have tested a different monitor?
Let me Know.
Isak, can you also post your dxdiag report here and if possible your graphics report?
IDals
初學者
4,785 檢視
I have not tried with a different TV.
This works with AMD graphics card:
Monitor+TV in clone mode
TV in single mode
Monitor in single mode
This also works with Intel 4600:
TV in single mode
This doesn't work with Intel 4600:
Monitor (VGA)+TV (DVI) in clone mode.
The TV can't possibly be the problem here.. I'll try extended/dual desktop when I get home. I haven't tried that yet.. And no, my AMD graphics card hasn't been installed in setup (new mobo and cpu).
JSpaa
初學者
4,785 檢視
Kevin,
Yes i tested with another monitor and problem is the same.
JSpaa
初學者
4,785 檢視
Isak,
Which amd graphics card are you referring to?
Kevin_M_Intel
員工
4,785 檢視
Hi Guys,
I will try to replicate this issue and I will be back with more information.
JSpaa
初學者
4,785 檢視
The tearing is so obvious in my case:
it is already happening while moving a windows explorer window around...
JSpaa
初學者
4,785 檢視
Think i solved the problem!
After installation my television is the primary screen and the monitor is the secundary screen.
After making the monitor the primary screen in the clone setup, the tearing has gone!
i'm running driver 9.18.10.3257
I will keep testing of course..
cheers,
Jerome.
Kevin_M_Intel
員工
4,785 檢視
Thanks for the feedback. At this point I am stalling the OS and I will try it soon… Keep us posted.
SSerr1
初學者
4,676 檢視
I have this issue with only ONE monitor. It's pervasive- windows explorer, flash videos, mp4, avi, mkv, when scrolling a web page....
Almost always a rectangle of tearing in the bottom-left portion of the screen. This is ridiculous.
Intel HD 4600; Haswell i5; z87
8GB DDR3
Windows 7 Pro sp1 on 160GB SSD
... What gives here? Why must this be so difficult?
MMISS57
初學者
4,676 檢視
Hi All,
If it is happening on the built in display, then
You should check your windows aero settings on win7 and win 8.
Like start menu + aero and select the lower item ...For example I was on the classic theme which does not support aero. For me switching aero on fixed the tearing 100% with one screen. For cloned screen, I haven't tested. But I will keep this idea to select the tv as primary.
Thanks everyone for good ideas and sharing experience.
BR
Juliuz
Kevin_M_Intel
員工
4,676 檢視
Hi sserra,
I personally have been testing the Intel® DZ87KLT-75K board using an i7-4770K and I have not been able to reproduce any screen tearing issue so far.
I recommend you to update the bios and graphics drivers to the latest provided by Intel®. Besides updating these drivers, Installing the monitor drivers and testing different cables are good steps to take.
IDals
初學者
4,785 檢視
I also have massive screen-tearing from my new 4670K (Asus Z87-PRO mobo) with Windows 7 x64.
I use VGA to my main monitor and DVI to my TV. Then I duplicate the screens and see lots of screan-tearing when I use full sreen video (Netflix, Youtube, Windows Media Player Classic).
If I only use the TV there is no screan-tearing.
I've the latest BIOS. Tried the driver version on Asus website, the latest version Kevin links to above and I've run out of ideas. if there are anymore info I can give you please tell me.
IDals
初學者
4,785 檢視
The AMD graphic card I am referring to is just the card I had before I had this cpu+mobo combo. I was just trying to point out that the TV is not the problem here..
If I use extended mode everything is perfect. It's just clone. And I got a longer cable for my mouse and can confirm that it's not just full screen video. It's always there. A browser window that I move around with the mouse for example.
回覆
