22872 Discussions
Second monitor connection problem (software related problem)
mRHiggs
Hi. I have an old monitor (DVI - 1440x900). I bought an HDMI to DVI converter and was using this monitor as a second display. The old Intel Graphic Control Panel software finds my monitor but the new software cannot find my monitor. Also, when I search from the settings section of windows, my monitor does not appear. What is the reason of this? Is there a solution?
That's why I copied the old Intel Graphic Control Panel software's file and still using it.
New software that can't find my screen:
new software that can't find my monitornew software that can't find my monitor
Old software that found my screen:
Old software that found my monitorOld software that found my monitor
IsaacQ_Intel
Hello mRHiggs
Thank you for posting on the Intel®️ communities and opening a new thread.
We understand you have also opened a web portal support case with us, so, in this case, will continue to help you through that channel now. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel, in case that you have further questions, please open a new thread.
Thanks for your understanding.
Isaac Q.
