22839 Discussions
Sine Mora EX crashes after loading once it gets to 100% loading. Using DXVK the issue gets fixed
laxesta
New Contributor II
I have the game on Steam. Resizable BAR is enabled in the BIOS.
The game launches normally, then it starts loading. Once it gets to 100% it continues to load something but after a few seconds the game crashes to the desktop.
According to PCGamingWiki the game is D3D9 32bits. I used the DXVK corresponding files and the game runs perfectly fine.
I attach the SSU file of my system.
Jean_Intel
Hello laxesta,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing playing  Mora EX.
  • Does the issue occur if you use different drivers?
  • Do you receive an error message when the game crashes? If so, provide us with a screenshot of the error message.
  • For reproduction purposes, could you share a step-by-step of the issue you experience? If it is possible, a video will be ideal.
Also, perform a clean installation of the latest production driver, 31.0.101.4146.  Sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected. It is important to mention that BETA releases are for targeted testing.
Jean O.
Jean_Intel
Hello laxesta,
Jean O.
laxesta
New Contributor II
thanks for the reply @Jean_Intel .
I performed a clean installation using the new drivers and removing the DXVK files and the issue is fixed with the current drivers!
Btw, I always perform a clean installation when installing new drivers.
The issue happened with the previous drivers, which were the most updated ones a few days ago.
In regards to reproducing he previous issue, well, it was so easy, the game launched fine, there is a percentage spinner and when the game got to the 100% it continued loading for a few seconds, but never got to the main menu, it crashed straight to the desktop without a message.
That has been fixed now.
Jean_Intel
Hello laxesta,
We're glad to know the information helped. Hopefully, it will help other community members. Since the thread is now solved, we will close it.
Jean O.
