22657 Discusiones
Standby issue intel driver gfx_win_101.5085_101.5122
Stephen
Colaborador Valioso I
1.319 Vistas
Updated my Intel ARC GPU drivers to
For the last two days when the PC tries to engage standby mode it immediately shuts down.
I confirmed it's an issue with the above mentioned drive, when I rolled back to the previous
gfx_win_101.5084_101.5122
The issue has since disappeared/resolved.
Kindly look into this
0 kudos
1 Responder
Stephen
1.249 Vistas
*Update*
I run some more tests and, ...Now the gfx_win_101.5085_101.5122 driver has been working with no issue.
here is what I did.
I clean installed gfx_win_101.5084_101.5122 driver using the in-driver option.
Then installed gfx_win_101.5085_101.5122 driver on top I did not perform clean install.
was working fine then I decided to remove gfx_win_101.5085_101.5122 driver and run a clean install of it.
and all has been well ever since.
Responder
