I have a problem with my GPU when I play valorant. Past week I play that with almost high graphics and 60-100fps
system specifications are
HP Probook 450 G8
11th Gen Intel(R) Core(TM) i7-1165G7 @ 2.80GHz 2.80 GHz
16GB Ram
512 SSD
Now Its unplayable because fps suddenly drops to 100 to almost 0-5fps in seconds.
* I tried latest and new graphic drivers using DDU
*almost update and rollback windows updates
*re-installed the game
also cpu memory usage almost same as previous.
cpu like 65%
memory like 60%
GPU like 50%
but GPU suddenly drop 0% from that value.
please suggest me support.
Hi, Akila-Santhush.
Thank you for posting in our Community.
Given your system specifications, including an 11th Gen Intel Core i7 processor, 16GB of RAM, and a 512GB SSD, your setup should be capable of handling the game smoothly.
I would like to inform you that since this is a known issue, Intel is currently investigating this issue and as a workaround, turn on the Vignette option in the game settings to reduce stuttering. You may refer to this article:
This issue is being discussed on this Community thread.
Moreover, knowing your processor, RAM, and OEM device is a good start, but I could still use more information about your system configuration. Please run the Intel SSU report and share the results with me so I can verify details such as OS build, driver version, errors logged at the system level, etc.
Looking forward to your response. Have a nice day!
Von M.
Hi, Akila-Santhush.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Also SSU not installing in my device. so i used older version.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
