This isn't new. It's not a hardware or Microsoft software problem. It's an Intel graphics driver issue, definitively.
Please Intel, test on your own machine and then fix the issue. Do not ask every individual user for logs and versions, as that won't fix anything.
If there's a known fix, PLMK. Thank you.
Hello IrisGraphicsBroken,
Thank you for posting on the Intel️® communities. I am sorry to hear that you are experiencing flickering immediately.
Sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected. I would recommend you perform a Clean Installation of the Graphics driver:
- It is important to mention there are two different types of drivers, generics provided by Intel and Equipment Manufacturer drivers, that are customized to work with each specific system. The best thing to do is to use the drivers provided by the system manufacturer (OEM).
- Installing this Intel generic graphics driver will overwrite any customized driver from your Computer Manufacturer (OEM). Intel’s generic graphics drivers are intended for testing, if you want, you can try installing our latest driver 31.0.101.3790.
Also, you should make sure that the operating system is up to date:
- Click the Start button.
- Search for Windows Update.
- Click Check for Updates and run all pertinent updates.
Jean O.
We appreciate your response.
We noticed that you have marked this thread as solved; however, we would like to know if you need anything else from us, we are here to assist you with Technical Support and possible Troubleshooting anytime you need it.
Jean O.
I would add that you were NOT asked to uninstall the driver; you were asked to install the original driver provided by MS - you know, the one that they (supposedly) tested with their hardware? If that works, but subsequent drivers do not, it is typically an indication of a problem in the system's BIOS (i.e., out of date Video BIOS).
I have the same issue: the screen flickers when using the Intel Iris Graphics driver. If I uninstall it and use the default Windows driver, the flickering stops, but smooth scrolling is lost. Is there any working solution other than reverting to the Windows driver?
lenovo yoga 14prox
intel 12500h
