22661 Discussions
Toshiba C850 notebook hd 4000 display driver (Win 10)
ZZsol
The driver runs well after hot restart. If I stop the machine completely and restart it (cold restart) the shapness of pictures and texts will be much worse, however it is shown that the resolution is the same (1366x768). I tried to install older drivers in compatibility mode, but the situation is the same. Mamory conflict, registry problem or what else could be the matter?
ZZsol
Solved. Fast startup have to be switched off in Windows 10.
ZZsol
Hi Mojo_blues,
Great to know you could find a solution for your issue, do not hesitate to contact us back If there is anything else you need.
Hellen.
