The driver runs well after hot restart. If I stop the machine completely and restart it (cold restart) the shapness of pictures and texts will be much worse, however it is shown that the resolution is the same (1366x768). I tried to install older drivers in compatibility mode, but the situation is the same. Mamory conflict, registry problem or what else could be the matter?
Solved. Fast startup have to be switched off in Windows 10.
Hi Mojo_blues,
Great to know you could find a solution for your issue, do not hesitate to contact us back If there is anything else you need.
Hellen.
