Toshiba DLP TV shows NoVideo Signal Detected when I attempt to connect VGA out on computer to VGA in on TV. Can anyone assist?
Hello, tpb001739:
You could test the following:
1. Use a different VGA cable to connect the system.
2. If not currently using, use a straight connection between both devices (VGA to VGA).
3. Also, you could test using a different video output is possible to discard that as the issue.
4. Make sure the correct source is selected in your TV, it could be PC or VGA.
Esteban C
Hello, tpb001739:
Esteban C
For more complete information about compiler optimizations, see our Optimization Notice.
