22671 Discussions
Trying to connect VGA out on computer to VGA in on Toshiba DLP TV. No signal detected by TV. Can onyone assist.
TBail1
Toshiba DLP TV shows NoVideo Signal Detected when I attempt to connect VGA out on computer to VGA in on TV. Can anyone assist?
EstebanA_C_Intel
Hello, tpb001739:
You could test the following:
1. Use a different VGA cable to connect the system.
2. If not currently using, use a straight connection between both devices (VGA to VGA).
3. Also, you could test using a different video output is possible to discard that as the issue.
4. Make sure the correct source is selected in your TV, it could be PC or VGA.
Esteban C
EstebanA_C_Intel
Hello, tpb001739:
Esteban C
