22681 Обсуждение
UHD630 - multiple issues. seasoned user but out of ideas.
KLepp
Начинающий
2 795Просмотр.
Let me begin by describing my setup. its definitely niche but that should be irrelevant.
I run an 8700k with SLI discrete gpu's output to 4 monitors in portrait mode. the first 3 are set up as a surround display, the 4th is an accessory display.
For the longest ive ran everything powered by the discrete gpus and had the igpu disabled. However as of late, a combination of a new central air unit, and having kids - ive become a little more budget conscious we'll say
For reasons that are again, not relevant - nvidia forces their driver to run the gpu at 3d clocks if >3 displays are connected. Even this could be rectified if you could connect your displays to "both" cards and still use Surround, alas this has been broken since 368.51 in june of 16 and I dont expect it will ever be fixed. At least not on this architecture.
So that left me with few options
1) no accessory display
2) no surround
3) very high idle clocks/energy wasted/heat
4) which is my current solution (use multi dispay power saver) which forces the clocks to p8 rest state based on defined paramaters (in my case, <10% gpu usage)
Then came the eureka moment. I could use the iGPU for the accessory display! So i quickly fetched a DP cable, enabled it in the efi, and installed the latest drivers. First issue was the nvlkkdm.sys (going from memory so might be # spelling) bluescreens. No matter which drivers I tried, they wouldnt get along. Also crashed outlook which was due to hardware acceleration. Forcing that off fixed the outlook issue - alas they still caused an nvidia driver crash.
At that point I decided to revert to # 4 above, but keep the igpu enabled. I am watercooled so the additional heat isnt of consequence and it would be useful for using quicksync for this or that. I own several steam links and was having some issues with latest firmwares and the nvenc encoder so I wanted to try it.
Unfortunately, using quicksync also presented me with (slowly over a short time span) more and more artifacts until it crashed.
So again, with hopes it was a driver issue, I decided to for-go using quicksync for now and simply let it sit enabled so I had the option if i so chose.
This brings me to the issue which forced me to post. This ones the deal breaker.
As ive mentioned, I use an accessory display and SLI coupled with nvsurround. The latter forces me to game at a very high resolution which requires the use of SLI for acceptable framerates at acceptable settings. Because of technological limits which are unfortunately well above my pay-grade even after a decade in the market SLI does not function unless it has exclusive full-screen. The reason this matters is it would render my accessory display completely moot.
Fortunately several developers have come along and offer solutions which varying names. DisplayFusion+Prevent deactivation is the combination of software/feature I use. It forces the game window to keep focus when you alt tab, and allows you to move your mouse freely between the game and the accessory display. Amazing this can be done with third party software developed by a small company but.........ah nevermind, thats getting off topic.
So the short of it is - if i have the iGPU enabled, if I start a game and then use my accessory display, everything on it lags when I minimize or maximize it. Huge lag..
This is when the igpu is enabled in bios, enabled in device manager, but NOT physically connected to my displays. If i disable it in device manager (and presumeably the bios which is my next step should i not be able to fix this as its offering me 0 and causing tons of issues) the problem goes away completely.
If i re enable, it comes back. I can do this without even leaving the game and watch the issue come and go.
What im trying to understand is what/why or how its doing ANYTHING not connected physically to my display? Anything I can do about it?
Is it a driver conflict that may be related to the crashes I was getting when trying to power the accessory display off the igpu to begin with?
Am i stuck with igpu or discrete but both just simply isnt going to work?
Hope someone higher up the ladder can give me some suggestions or insight cause im all out. I apologize for the huge book but I imagine much of it was necessary/relevant.
0 баллов
4 Ответы
Сотрудник
1 695Просмотр.
Hello klepp0906,
Thank you for joining the Intel Community Support.
I understand that you are having some issues with Intel® UHD graphics 630 and discrete graphics card. I would like to help you with this.
First, I would like to get more information about your system, please run the Intel® System Support Utility and attach the report.
1.Download the Intel® System Support Utility and save the application to your system.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
Then, how are you connecting your monitors? Please describe.
Wanner G.
KLepp
Начинающий
1 695Просмотр.
Hi and thank you for getting back. I am running the scan you requested as we speak. I have all my displays connected via Displayport. Each gpu has the option for DP/HDMI/DVI however as mentioned, Surround has been broken by nvidias drivers in any "two card" connection config since june of 16/driver 368.51.
Therefore I have all the displays connected to the top card. Integrated graphics aside, I run with my 3 main displays connected via Displayport and my accessory display connected via DVI.
The integrated graphics presents issues connected or not. When I do connect it, I also connect it via Displayport. The nvidia driver crashes/conflicts when going between the two screens at seemingly random caused me to disconnect it, revert to having my discrete gpu(s) power the accessory display - and just attempt to use the UHD630 for quicksync type functions.
Unfortunately it gives me artifacts when using quicksync and steamlink. Crashes handbrake with the quicksync profile, and somehow as i mentioned - without being connected to anything, causes lag when opening and closing windows on my accessory display while fullscreen gaming.
A simple disable in device manager and the lag goes away. I'm perplexed.
Could it need more voltage in the bios? Everything is set to auto but adjustements do exist for current/voltage and even clocks i believe. Perhaps auto is giving it too little (even though its usualy the opposite).
I could see something like that being related to the artifacting and even the crashing, but I still cant understand how its causing slowdown on my accessory display while the monitor isnt even connected to it.
Submitting the log now.
Сотрудник
1 695Просмотр.
Hello klepp0906,
Thank you for your response.
I will do research about this issue. I will get back to you soon.
Wanner G.
KLepp
Начинающий
1 695Просмотр.
Hi again. I seem to have resolved the issue. Apparently the uncore needed a little voltage bump and all issues went away. Weird considering the igpu was at default and the system never had any other issues until it was enabled.
That being said - perhaps it's due to having a ton of ram installed.
Either way it's sorted - thanks for your time!
Ответить
