22668 토론
Unable to get Intel Driver Support Assistant to work on Windows 10
S8teo
초급자
3,302 조회수
I am having some difficulty trying to use Intel Driver Support Assistant to download and install new drivers. Whenever I right-click on the Intel DSA icon in my toolbar to check for new drivers, I get the error message "Sorry, something went wrong while trying to scan."
It used to work couple of months ago but I can no longer download new drivers. I've already tried uninstalling and using the Uninstaller tool and re-installing it again.
레이블 (1)
0 포인트
8 응답
AlHill
수퍼 사용자
3,275 조회수
You provided no information about your PC.
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
0 포인트
S8teo
초급자
3,262 조회수
Here
0 포인트
Maria_R_Intel
중재자
3,210 조회수
Hello S8teo,
Thank you for posting on the Intel* Community.
Keep in mind that when Intel® DSA cannot detect your device, it's due to the following reasons:
  • You have an older component.
  • Your component is discontinued or isn't supported.
  • You have a component not produced by Intel.
  • You have a customized driver pre-installed by the computer manufacturer.
  • The component isn't in Intel's database.
Please follow the below recommendations:
1. Try testing all the different validated browsers: Chrome, Firefox, or Edge*
We understand that you already try those steps but it is to have new LOGs in case the issue persists.
2. Uninstall the existing Intel®️ Driver & Support Assistant (Intel®️ DSA) from Apps and Features:
  • Click Start.
  • Open Control Panel.
  • Select Programs.
  • Select Programs and Features.
  • From the list that displays, click Intel®️ Driver & Support Assistant.
  • Click Uninstall.
  • A new window opens that offers to uninstall the program.
3. Remove any remaining files from the Intel®️ DSA in the system using the Uninstaller tool. https://downloadcenter.intel.com/download/30193/Intel-Driver-Support-Assistant-Uninstaller?v=t
4. Download and reinstall the latest Intel®️ DSA version 21.1.5.2  https://downloadcenter.intel.com/download/28425/Intel-Driver-Support-Assistant, run the installer as administrator (right-click on the icon and choose Run as Administrator).
5. In case the problem appears again, please provide the Intel®️ Driver & Support Assistant logs? In order to get them, please follow these instructions:
  • Press Windows key + E (File explorer Windows will be opened with this key combination).
  • Click on "This PC."
  • Look for: Disk C:\ProgramData\Intel\DSA, and zip the Log files or the entire folder.
  • Note: In case you do not see the "ProgramData" folder click on the upper tab "View" and check the box "Hidden items".
Maria R.
0 포인트
S8teo
초급자
3,205 조회수
No, that is not the right model. It's a HP Notebook 15 ay110na.
0 포인트
S8teo
초급자
3,196 조회수
Okay, for some reason it seems to have worked when I tried Google Chrome.
0 포인트
Maria_R_Intel
중재자
3,169 조회수
Hello S8teo,
I'm glad to hear that! In this case, can we proceed to close this thread?
If the issue is not solved yet, please provide the requested logs by email, I will send you an e-mail to the e-mail address associated with your community profile.
Maria R.
0 포인트
S8teo
초급자
3,163 조회수
Yeah, sure. You can close this thread.
0 포인트
Maria_R_Intel
중재자
3,149 조회수
Thank you S8teo!
If you need further assistance do not hesitate to contact us back!
Maria R.
0 포인트
응답
