Environment | ||
Linux | ||
Distro | Ubuntu 24.10 | |
Kernel Build | 6.13.0-061300-generic | |
Machine Target | x86_64 | |
Version | #202501302155 SMP PREEMPT_DYNAMIC Sat Feb 8 09:06:55 UTC 2025 | |
DESKTOP_SESSION | ubuntu-xorg | |
DISPLAY | :0 |
Hardware | ||
CPUs | 16 | |
Memory | Physical Available | 30 GB |
System Disk Space | Free | 315 GB |
Current Dir Disk Space | Free | 316G |
Executable Info | |
Exe Directory | /usr/bin |
Current Directory | /home/posihdun/vulkan/1.4.304.1 |
App Version | Version 1.3 |
Vulkan API Version | 1.4.304 |
Byte Format | 64-bit |
I’m encountering issues with Vulkan not loading in Steam what stops me from running games that require dx12, and I'm not sure how to troubleshoot the problem.
Steps Taken:
- Tried to force Steam to use the system-wide Vulkan defaults.
- Discovered that Steam was using an older version of Vulkan when installed via Snap or Flatpak.
- Managed to get Steam (via the steam_installer.deb) to use the system-wide Vulkan, but I’m still getting the following error:
- 'VK_KHR_surface'
- 'VK_KHR_xlib_surface'
- I also tried running Steam through Wine, but it fails to start entirely.
- I downloaded Vulkan SDK and other tools to help with logging and debugging, but I haven’t made any progress.
- I was able to run raytracing bench marks with Phoronixs, hitting 65-90FPS maxed out settings @ 1920*1080.
It seems like Vulkan is working, but there may be a mismatch between the version of Vulkan that Steam is using and the one installed on my system.
I should note that I downloaded Vulkan samples from Git, but only a few of them run. It’s possible I compiled the package incorrectly.
I've attached the HTML and JSON (converted to text file) with my GPU and system information.
Any insight or steps for debugging would be greatly appreciated!
INFO:
GPU INFO UPLOAD
Edit: I want to note I have followed these steps and still doesn't help
Intel Drivers
INTEL GPU PREVIEW GIT
- Steam loads up successfully and OpenGL is enabled, but Vulkan isn't. I can run benchmarks in Steam, but only for titles that use lower than DX12.
Solved! Here's What Worked for Me:
This thread has gotten long, so I’m dropping the full solution here. After a lot of trial and error, I finally got everything working , and with that, I’m running the game smoothly!
Key Takeaways:
I tested Steam across Snap, .deb, and Flatpak versions, and here’s what I observed:
- Snap (Steam): Successfully builds GPU topology using Mesa driver 24 — decent performance.
- .deb (Steam): GPU topology refused to build no matter what I tried — completely broken for me.
- Flatpak (Steam): GPU topology builds successfully using Mesa driver 25, with llvmpipe as a fallback.
System Info:
Hardware:
- Motherboard: ASRock X570 Phantom Gaming 4
- CPU: AMD Ryzen™ 7 5800XT × 16
- GPU: Intel® Graphics (BMG G21)
- RAM: 32.0 GiB
- Storage: 2.5 TB
Software:
- Firmware: P5.63
- OS: Ubuntu 24.10 (64-bit)
- Kernel: Linux 6.14.1
- GNOME: Version 47
- Display Server: Wayland
OS: Freedesktop SDK 24.08 (Flatpak runtime)
KERNEL: 6.14.1-061401-generic
CPU: AMD Ryzen 7 5800XT 8-Core
GPU: Intel Mesa Intel (BMG G21)
GPU DRIVER: 4.6 Mesa 25.0.3 (git-c3afa2a74f)
RAM: 31 GB
The Breakthrough (Flatpak Fix):
Initially, Flatpak Steam also wouldn't load GPU topology properly(at first). This started while I was trying to get Steam to recognize an external drive for games already installed on my system.
I installed and ran:
flatpak run com.github.tchx84.Flatseal
I used Flatseal to grant Steam Flatpak permissions to access the drive, but that still didn’t work. Frustrated, I hit the reset button in Flatseal , not knowing what it would do.
After that, I restarted Steam (Flatpak) and boom! GPU topology built successfully using the latest Mesa Vulkan drivers , no errors whatsoever.
FF7 Rebirth:
Even though other games started running flawlessly (no screen tearing, no weird issues), FF7 Rebirth still threw a DirectX error on launch.
So I dug deeper and added the following to the launch options:
VKD3D_CONFIG=dxr VKD3D_FEATURE_LEVEL=12_2 VKD3D_SHADER_MODEL=6_6 %command%
Launched the game , shaders started compiling , and minutes later I’m running around in the open world. Absolutely smooth!
Final Thoughts:
From my experience:
- Flatpak Steam = best choice. Clean, modern Mesa drivers. Easy to control permissions using Flatseal.
- Snap Steam = just okay. Some compatibility issues, but at least it builds GPU topology.
- .deb Steam = nightmare. Broken GPU detection, failed builds, and just generally not worth the hassle right now.
If you're on Ubuntu with newer hardware and using Mesa and VKD3D, I highly recommend Flatpak Steam paired with Flatseal for control.
Let me know if anyone needs help replicating this setup — happy to share more!
链接已复制
Executable Info😁 | |
Vulkan Driver Info | ||
Standard Paths | ||
/etc/vulkan/icd.d | ||
/usr/share/vulkan/icd.d | ||
[0] | radeon_icd.x86_64.json | |
JSON File Version | 1.0.0 | |
API Version | 1.4.305 | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_radeon.so | |
[1] | intel_hasvk_icd.x86_64.json | |
API Version | 1.3.305 | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_intel_hasvk.so | |
[2] | virtio_icd.x86_64.json | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_virtio.so | |
[3] | lvp_icd.x86_64.json | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_lvp.so | |
[4] | virtio_icd.i686.json | |
Library Path | /usr/lib/i386-linux-gnu/libvulkan_virtio.so | |
FAILED TO LOAD! | /usr/lib/i386-linux-gnu/libvulkan_virtio.so: wrong ELF class: ELFCLASS32 | |
[5] | radeon_icd.i686.json | |
Library Path | /usr/lib/i386-linux-gnu/libvulkan_radeon.so | |
FAILED TO LOAD! | /usr/lib/i386-linux-gnu/libvulkan_radeon.so: wrong ELF class: ELFCLASS32 | |
[6] | intel_icd.x86_64.json | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_intel.so | |
[7] | intel_hasvk_icd.i686.json | |
Library Path | /usr/lib/i386-linux-gnu/libvulkan_intel_hasvk.so | |
FAILED TO LOAD! | /usr/lib/i386-linux-gnu/libvulkan_intel_hasvk.so: wrong ELF class: ELFCLASS32 | |
[8] | intel_icd.i686.json | |
Library Path | /usr/lib/i386-linux-gnu/libvulkan_intel.so | |
FAILED TO LOAD! | /usr/lib/i386-linux-gnu/libvulkan_intel.so: wrong ELF class: ELFCLASS32 | |
[9] | lvp_icd.i686.json | |
Library Path | /usr/lib/i386-linux-gnu/libvulkan_lvp.so | |
FAILED TO LOAD! | /usr/lib/i386-linux-gnu/libvulkan_lvp.so: wrong ELF class: ELFCLASS32 | |
[10] | dzn_icd.x86_64.json | |
API Version | 1.1.305 | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_dzn.so | |
[11] | nouveau_icd.x86_64.json | |
Library Path | /usr/lib/x86_64-linux-gnu/libvulkan_nouveau.so | |
/usr/local/etc/vulkan/icd.d | No such folder | |
/usr/local/share/vulkan/icd.d | No such folder | |
/home/posihdun/.local/share/vulkan/icd.d | No such folder | |
VK_ICD_FILENAMES | /usr/share/vulkan/icd.d/intel_icd.x86_64.json | |
/usr/share/vulkan/icd.d/intel_icd.x86_64.json | ||
Vulkan Runtimes | ||
Possible Runtime Folders | ||
/usr/lib | ||
No libvulkan.so files found | ||
/usr/lib/x86_64-linux-gnu | ||
[0] | /usr/lib/x86_64-linux-gnu/libvulkan.so.1 | libvulkan.so.1.4.304 |
/usr/lib64 | ||
/usr/local/lib | ||
[0] | /usr/local/lib/libvulkan.so.1 | libvulkan.so.1.4.304 |
/usr/local/lib64 | No such folder | |
Runtime Folder Used By via | /usr/local/lib | |
Vulkan SDKs | |||
System Installed SDK | vulkan-sdk | 1.4.304.0~rc1-1lunarg24.04-1 |
Vulkan Implicit Layers | |||
/etc/vulkan/implicit_layer.d | Directory does not exist | ||
/usr/share/vulkan/implicit_layer.d | |||
[0] | VkLayer_MESA_device_select.json | ||
Name | VK_LAYER_MESA_device_select | ||
Description | Linux device selection layer | ||
API Version | 1.4.303 | ||
JSON File Version | 1.0.0 | ||
Library Path | libVkLayer_MESA_device_select.so | ||
Enabled State | ENABLED | ||
Enable Env Var | --NONE-- | Not Defined | |
Disable Env Var | NODEVICE_SELECT | Not Defined | |
/usr/local/etc/vulkan/implicit_layer.d | Directory does not exist | ||
/usr/local/share/vulkan/implicit_layer.d | Directory does not exist | ||
/home/posihdun/.local/share/vulkan/implicit_layer.d | |||
[1] | steamfossilize_i386.json | ||
Name | VK_LAYER_VALVE_steam_fossilize_32 | ||
Description | Steam Pipeline Caching Layer | ||
API Version | 1.3.207 | ||
Library Path | /home/posihdun/.local/share/Steam/ubuntu12_32/libVkLayer_steam_fossilize.so | ||
Enabled State | DISABLED | ||
Enable Env Var | ENABLE_VK_LAYER_VALVE_steam_fossilize_1 | Not Defined | |
Disable Env Var | DISABLE_VK_LAYER_VALVE_steam_fossilize_1 | Not Defined | |
[2] | steamfossilize_x86_64.json | ||
Name | VK_LAYER_VALVE_steam_fossilize_64 | ||
Library Path | /home/posihdun/.local/share/Steam/ubuntu12_64/libVkLayer_steam_fossilize.so | ||
[3] | steamoverlay_i386.json | ||
Name | VK_LAYER_VALVE_steam_overlay_32 | ||
Description | Steam Overlay Layer | ||
Library Path | /home/posihdun/.local/share/Steam/ubuntu12_32/steamoverlayvulkanlayer.so | ||
Enable Env Var | ENABLE_VK_LAYER_VALVE_steam_overlay_1 | Not Defined | |
Disable Env Var | DISABLE_VK_LAYER_VALVE_steam_overlay_1 | Not Defined | |
[4] | steamoverlay_x86_64.json | ||
Name | VK_LAYER_VALVE_steam_overlay_64 | ||
Library Path | /home/posihdun/.local/share/Steam/ubuntu12_64/steamoverlayvulkanlayer.so | ||
Vulkan Explicit Layers | |||
VK_LAYER_PATH | |||
Path 0 | /usr/share/vulkan/explicit_layer.d | ||
[0] | VkLayer_INTEL_nullhw.json | ||
Name | VK_LAYER_INTEL_nullhw | ||
Description | INTEL NULL HW | ||
API Version | 1.1.73 | ||
Library Path | libVkLayer_INTEL_nullhw.so | ||
[1] | VkLayer_khronos_validation.json | ||
Name | VK_LAYER_KHRONOS_validation | ||
Description | Khronos Validation Layer | ||
API Version | 1.4.304 | ||
JSON File Version | 1.2.0 | ||
Library Path | libVkLayer_khronos_validation.so | ||
Device Extensions | 3 | ||
[0] | VK_EXT_debug_marker | ||
[0] | VK_EXT_validation_cache | ||
[0] | VK_EXT_tooling_info | ||
Instance Extensions | 4 | ||
[0] | VK_EXT_debug_report | ||
[0] | VK_EXT_debug_utils | ||
[0] | VK_EXT_layer_settings | ||
[0] | VK_EXT_validation_features | ||
[2] | VkLayer_khronos_profiles.json | ||
Name | VK_LAYER_KHRONOS_profiles | ||
Description | Khronos Profiles layer | ||
JSON File Version | 1.2.1 | ||
Library Path | libVkLayer_khronos_profiles.so | ||
Device Extensions | 1 | ||
Instance Extensions | 1 | ||
[3] | VkLayer_khronos_synchronization2.json | ||
Name | VK_LAYER_KHRONOS_synchronization2 | ||
Description | Khronos Synchronization2 layer | ||
Library Path | libVkLayer_khronos_synchronization2.so | ||
[0] | VK_KHR_synchronization2 | ||
[4] | VkLayer_api_dump.json | ||
Name | VK_LAYER_LUNARG_api_dump | ||
Description | LunarG API dump layer | ||
Library Path | libVkLayer_api_dump.so | ||
[5] | VkLayer_MESA_overlay.json | ||
Name | VK_LAYER_MESA_overlay | ||
Description | Mesa Overlay layer | ||
Library Path | libVkLayer_MESA_overlay.so | ||
[6] | VkLayer_khronos_shader_object.json | ||
Name | VK_LAYER_KHRONOS_shader_object | ||
Description | Khronos Shader object layer | ||
Library Path | libVkLayer_khronos_shader_object.so | ||
[0] | VK_EXT_shader_object | ||
[7] | VkLayer_monitor.json | ||
Name | VK_LAYER_LUNARG_monitor | ||
Description | Execution Monitoring Layer | ||
Library Path | libVkLayer_monitor.so | ||
[8] | VkLayer_crash_diagnostic.json | ||
Name | VK_LAYER_LUNARG_crash_diagnostic | ||
Description | Crash Diagnostic Layer is a crash/hang debugging tool that helps determines GPU progress in a Vulkan application. | ||
Library Path | libVkLayer_crash_diagnostic.so | ||
Device Extensions | 2 | ||
Instance Extensions | 3 | ||
[9] | VkLayer_gfxreconstruct.json | ||
Name | VK_LAYER_LUNARG_gfxreconstruct | ||
Description | GFXReconstruct Capture Layer Version 1.0.5-unknown | ||
Library Path | libVkLayer_gfxreconstruct.so | ||
[10] | VkLayer_screenshot.json | ||
Name | VK_LAYER_LUNARG_screenshot | ||
Description | LunarG image capture layer | ||
Library Path | libVkLayer_screenshot.so | ||
Standard Paths | |||
/etc/vulkan | /etc/vulkan/explicit_layer.d | No such folder | |
/usr/share/vulkan | /usr/share/vulkan/explicit_layer.d | ||
/usr/local/etc/vulkan | /usr/local/etc/vulkan/explicit_layer.d | No such folder | |
/usr/local/share/vulkan | /usr/local/share/vulkan/explicit_layer.d | ||
[0] | VkLayer_khronos_validation.json | ||
[1] | VkLayer_khronos_profiles.json | ||
[2] | VkLayer_khronos_synchronization2.json | ||
[3] | VkLayer_api_dump.json | ||
[4] | VkLayer_khronos_shader_object.json | ||
[5] | VkLayer_monitor.json | ||
[6] | VkLayer_crash_diagnostic.json | ||
[7] | VkLayer_gfxreconstruct.json | ||
Description | GFXReconstruct Capture Layer Version 1.0.5 | ||
[8] | VkLayer_screenshot.json | ||
$HOME/.local/share/vulkan/explicit_layer.d | /home/posihdun/.local/share/vulkan/explicit_layer.d | No such folder |
Hi Posihdun,
I'm sorry to hear that your system is giving you trouble. Please supply the information requested here so that we may better assist you and identify the best course of action. We can better adapt our service to your unique circumstances with the use of this information:
- Have you tried updating your Graphics Drivers to the latest version?
- is your system working fine before you encounter this issue? if yes, what are the changes on the system before the issue happen?
Also, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
First of all, I am using Ubuntu and have tested my GPU in Windows, where it functions without issues.
When I first installed my GPU, I was running Ubuntu 24.04 with Kernel 6.8, but the card was not cooperating with my system at all. After updating to Ubuntu 24.10 and the latest Kernel 6.13, my system was able to utilize the card properly.
However, the issue arises when trying to load applications that require DirectX 12 (Dx12) aka Vulkan in steam. This might be beyond the scope of this forum, but I wanted to see if anyone has insights on potential solutions.
For reference, my GPU works perfectly fine for development tasks such as Android development and other workloads without any issues.
System Details
Hardware Information:
- Memory: 32.0 GiB
- Processor: AMD Ryzen™ 7 5800XT (16 Threads)
- Graphics: Intel® Graphics (BMG G21)
- Storage: 2.5 TB
Software Information:
- Firmware Version: P5.63
- GNOME Version: 47
- Windowing System: Wayland
- Kernel Version: Linux 6.13.0-061300-generic
Any suggestions or insights would be greatly appreciated!
Hello Posihdun,
Thank you for sharing this information with us.
No worries, I'll check on this internally and provide you an insight on this thread as soon as I can.
Earl E.
Hello Posihdun,
I just have a few clarifications regarding to the issue:
- May I know if you're a game developer or application developer? are you trying to develop a game or application?
Earl E.
Hello Posihdun,
Thank you for clarifying this with us.
Noted on this, I will further check what I can do on the issue you brought up.
I'll provide you an update on this thread as soon as possible.
Earl E.
Hello Posihdun,
As this issue is still being investigated, I need to confirm which other games besides Final Fantasy 7 Rebirth is having issues with launching from Steam in Ubuntu. Kindly verify if you have enabled Proton compatibility in Steam as well and if so, which versions have you tried using.
I will wait for your reply.
JeanetteC.
Any game that requires DX12 will not run....
Proton compatibility Later has been enabled. I've tried:
Proton 6 and higher
Proton experimental | HotFix
Proton Glorious EggRoll
None of these are working.
Hello Posihdun,
I'll take note of this and will continue with the further investigation of this issue. I'll reach out to you in case more details are needed and will post an update once available.
JeanetteC.
Hi Posihdun,
Thank you for patiently waiting.
I was unable to reproduce the issue. I was able to run 2 DirectX 12 games correctly on Ubuntu 24.10 and Intel Arc B580 GPU.
* For this test I followed these steps:
- Started on a fresh Ubuntu installation
- Then followed by adding the Intel drivers as noted here: Installing Client GPUs — Intel® software for general purpose GPU capabilities documentation
- Restart
- Installed Steam and let it update.
- In Steam -] Compatibility -] Enabled Proton.
- Installed Age of Empires 2 and Cyberpunk 2077.
Recording my test here: Ubuntu 24.10 - DIrectX 12 Steam games test - Arc B580 GPU
For reference I'm attaching .txt files for Intel SSU, vulkaninfo report and clinfo so you can compare and check for differences.
If issue persists, then I suggest following the same steps as outlined above and re-test.
Earl E.
Hello Podishdun,
Thanks for the response.
I'll check internally if I can gather the steps on how to install Steam and the system info provided by Steam.
I'll share an update on this thread as soon as I can.
Earl E.
Hi Podishdun,
Thanks for patiently waiting.
Steam was installed by downloading the latest .deb file from the steam website -] double-clicking on it so it opened the installer from the App Center.
Attached are the required files from Steam, SSU and vulkantools.
Earl E.
I've matched the drivers and settings to your setup but still can't get the game to load. After checking other sources, it seems like others are experiencing the same issue.
At this point, I haven't been able to find a solution, so I think we can close this thread as unresolved. I'll continue troubleshooting and may need bark up Steam/Valve tree for further answers.
I really appreciate your assistance—this process has been incredibly valuable, and I've learned a lot along the way.
I should note that Vulkan works fine, and I'm able to run benchmark tests locally. This leads me to believe the issue is more on Steam/Valve and Square Enix's end, specifically regarding the Arc B580's inability to launch Final Fantasy 7 Rebirth.
Hello, Podishdun.
Thank you for your detailed update. I understand how frustrating it can be to encounter such persistent issues, especially after matching drivers and settings. It's helpful to know that others are experiencing the same problem, which suggests a broader compatibility issue. Given that Vulkan works fine and you're able to run benchmark tests locally, it does seem likely that the issue lies with Steam/Valve and Square Enix's handling of the Intel Arc B580 for Final Fantasy 7 Rebirth. I appreciate your patience and the troubleshooting efforts you've made so far.
Closing this thread as unresolved is understandable. However, let me see what I can do for this case. I'll conduct additional research on this matter and will post an update in this thread once I have more information.
Von M.
From analyzing the logs in the attached images, I’ve pinpointed potential key issues affecting Steam and the game launch:
1. Vulkan Initialization Failure
- Vulkan missing requested extension 'VK_KHR_surface'
- Vulkan missing requested extension 'VK_KHR_xlib_surface'
- BInit - Unable to initialize Vulkan!
2. Incorrect ELF Class for Steam Overlay
The second image highlights a compatibility issue: Note I am using Proton
- ERROR: ld.so: object '/home/posihdun/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
This error occurs because Steam is attempting to load a 32-bit shared object (.so file) on a 64-bit system. Since the game may require 32-bit libraries, this mismatch could be causing instability.
3. Wine and D3D12 Issues
The logs also mention:
- Steam_SetMinidumpSteamID: Caching Steam ID: 76561198148174804 [API loaded no]
- wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
- Initializing D3D12.
- Unable to read VR Path Registry from C:\users\steamuser\AppData\Local\openvr\openvrpaths.vrpath
- Fossilize INFO: Overriding serialization path: "/home/posihdun/.local/share/Steam/shader_cache_temp_dir_d3d12_64/fozpipelinesv6/steamapprun_pipeline_cache".
The primary issue appears to be Vulkan failing to initialize, likely due to missing drivers or improperly installed Vulkan support. The secondary issue is the ELF class mismatch, where Steam is attempting to load 32-bit components on a 64-bit system. These two problems combined are likely preventing the game from launching properly.
Hi Posihdun,
Thanks for sharing this useful information with us.
Upon further checking, it will be beneficial for you to continue the investigation by contacting Steam/Valve.
It would also help to share this thread to the Steam/Valve to speed up their investigation since you already provided a wealth of information on the troubleshooting process that you undertook to address the issue.
If you need further assistance, please submit a new question as this thread will no longer be monitored.
Earl E.
