22971 Discussions
Will Intel UHD Graphics 620 support 3840x1080 (32:9)?
TravisB
I want to buy an ultrawide monitor, 32:9 ratio, 3840x1080 resolution. I'll swap between using it as a monitor for my personal pc and my work laptop (I mostly telework). Since this is a work laptop, I'll not be able to change anything like using different drivers.
The work laptop is:
Model: HP ProBook 640 G5
Processor: Intel® Core™ i5-8365UE
Embedded graphics: Intel UHD Graphics 620
The processor specs page says the HDMI port will support a maximum resolution of 4096x2304@24Hz.
https://ark.intel.com/content/www/us/en/ark/products/193559/intel-core-i58365ue-processor-6m-cache-up-to-4-10-ghz.html
This page, Determine Maximum Supported Resolution on Intel Graphics Technology, says "Most devices will support any resolution and refresh rate up to the maximum value listed". I know many graphics systems will only support certain standard resolution modes.
https://www.intel.com/content/www/us/en/support/articles/000023781/graphics.html
So my question is whether "any" means "any" or "any standard". Will this processor/graphics support the ultrawide resolution?
Alx24
New Contributor II
The most detailed information about Intel Corp. Core processors and their graphics:
https://www.intel.com/content/www/us/en/products/docs/processors/core/core-technical-resources.html
"Technical Resources: Intel® Core™ Processors"
https://www.intel.com/content/www/us/en/products/docs/processors/core/8th-gen-core-family-datasheet-vol-1.html
"9th/8th Generation Intel® Core™ Processor Family"
Download file
"337344_8th-gen-core-family-datasheet-vol-1_Rev008.pdf"
2.5.9 Multiple Display Configurations (Dual Channel DDR)
Table 2-31. Maximum Display Resolution
Table 2-32. Maximum Display Resolution
Table 2-33. Maximum Display Resolution
2.5.10 Multiple Display Configurations (Single Channel DDR)
Table 2-34.
Table 2-35.
indicate a significant complex dependence of the resolution value on the memory used, for example, in a laptop.
A modern perfect formulation of this
"Resolution support is subject to memory BW (bandwidth) availability."
The 3840x1080 is part of the 4K normal low-frequency resolution at 24 Hz, 60 Hz, but there are gaming monitors with frequencies of 100-120 Hz.
First Core processors of Intel Corp. with 4K Graphics
"Intel® HD Graphics 4400"
https://ark.intel.com/content/www/us/en/ark/products/graphics/81497/intel-hd-graphics-4400.html
Alx24.
TravisB
My gaming system will put out 60-120Hz, but I don't need my work system to put out that refresh rate, and a slower one would be fine when I've got the work laptop docked.
Yesterday I spoke with both Intel and HP support, but didn't get a definitive answer. My best understanding currently is that the monitor tells the PC what resolution modes it supports (discreet options), and then the hw/sw system can be told to put out any of those modes which are less than the max resolution - which means it should display at this resolution.
Thoughts?
Alx24
New Contributor II
EDIDs of high-frequency monitors contain several DTD blocks (Detailed Timing Data), which are described in detail
only high frequencies and support the HDMI 2.0 standard, which is not supported by eighth-generation processors and with modes with lower regeneration frequencies may unexpectedly encounter problems.
The 3840x1080 formally can even match the HDMI 1.4 frequency of 60 Hz since it is half of the 4K and that corresponds
3840x2160 at 30 Hz.
USB 3.1 Type-C, USB 3.1 ports allow you to use DisplayPort via USB-C connector ("The processor platform supports DP Type-C ..." ) or DisplayLink technology or Magic Control Technology Corp. but they do not have detailed specifications, look from the inside at the world around them completely individually and support a limited number of modes, so they require careful selection and study by reviews.
https://community.intel.com/t5/Graphics/HD-Graphics-520-ultrawide-monitor-compatibility/td-p/1329255 )
You can try to learn more about the monitor in advance through its EDID.
There is a general library of EDID's in WWW
https://github.com/linuxhw/EDID
The "DigitalDisplay.md" file on this page contains a table with manufacturer names, model, display name, resolution
https://github.com/linuxhw/EDID/blob/master/DigitalDisplay.md
for which later in the section
https://github.com/linuxhw/EDID/tree/master/Digital
Alx24.
Alx24
New Contributor II
Sample of 3840x1080 display
File: DigitalDisplay.md
| Samsung | SAM0E5D | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2020 | 68FFBE925AE9 |
| Samsung | SAM0E5D | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2019 | 50793C3D7F36 |
| Samsung | SAM0E5D | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2018 | 56E884DDAA76 |
| Samsung | SAM0E5D | C49HG9x | 1680x1050 | 1200x340mm | 49.1 | 2018 | 8968FAE68862 |
| Samsung | SAM0E5D | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2017 | 40D93564A91A |
| Samsung | SAM0E5E | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2020 | 48BE912B4B9C |
| Samsung | SAM0E5E | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2019 | 0AB992B4A262 |
| Samsung | SAM0E5E | C49HG9x | 1920x1080 | 1200x340mm | 49.1 | 2018 | 482B58F8E2FA |
| Samsung | SAM0E5E | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2018 | 7947ABD7B460 |
| Samsung | SAM0E5E | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | 2017 | 831F924E71EE |
| Samsung | SAM0E5E | C49HG9x | 3840x1080 | 1200x340mm | 49.1 | | E004B44D537D |
| Samsung | SAM0F20 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | 2019 | 708A61557719 |
| Samsung | SAM0F20 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | | 05C4D77A1573 |
| Samsung | SAM0F20 | C49J89x | 1920x1080 | 1200x340mm | 49.1 | | 46B714CC991A |
| Samsung | SAM0F21 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | 2020 | 97F4ABA96DCE |
| Samsung | SAM0F21 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | 2019 | B5BD0929051B |
| Samsung | SAM0F21 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | 2018 | B9E437714C9D |
| Samsung | SAM0F21 | C49J89x | 3840x1080 | 1200x340mm | 49.1 | | 2D2F58E32F59 |
| Samsung | SAM0F99 | C49RG9x | 3840x1080 | 1190x340mm | 48.7 | 2020 | 2BB6DC1C7E25 |
| Samsung | SAM0F99 | C49RG9x | 3840x2160 | 1190x340mm | 48.7 | | 1B29EF7B1EB4 |
| Samsung | SAM0F9A | C49RG9x | 3840x1080 | 1190x340mm | 48.7 | 2019 | 8C67B1A81DF0 |
| Samsung | SAM0F9C | C49RG9x | 2560x1440 | 1190x340mm | 48.7 | 2020 | 3E6F4621FB53 |
| Samsung | SAM0F9C | C49RG9x | 3840x1080 | 1190x340mm | 48.7 | 2019 | D5D44F7C68D3 |
| Samsung | SAM0F9C | C49RG9x | 3840x1080 | 1190x340mm | 48.7 | 2018 | 277769C0651C |
Sample - select by SAM0E5D
https://github.com/linuxhw/EDID/tree/master/Digital/Samsung/SAM0E5D
Sample - from list
https://github.com/linuxhw/EDID/blob/master/Digital/Samsung/SAM0E5D/40D93564A91A
edid-decode (hex):
00 ff ff ff ff ff ff 00 4c 2d 5d 0e 39 52 52 30
34 1b 01 03 80 78 22 78 2a cf f5 ae 4f 45 a8 26
0e 50 54 bf ef 80 71 4f 81 00 81 c0 81 80 95 00
a9 c0 b3 00 01 01 74 d6 00 a0 f0 38 40 40 30 20
3a 00 ac 50 41 00 00 1a 00 00 00 fd 00 18 78 1e
8c 3c 00 0a 20 20 20 20 20 20 00 00 00 fc 00 43
34 39 48 47 39 78 0a 20 20 20 20 20 00 00 00 ff
00 48 54 4a 4a 43 30 30 34 35 30 0a 20 20 01 20
02 03 40 f1 4f 90 61 1f 04 13 60 5d 5e 20 21 22
5f 03 12 5a 23 09 07 07 83 01 00 00 e3 05 c0 00
6d 03 0c 00 10 00 b8 3c 20 00 60 01 02 03 67 d8
5d c4 01 78 80 03 e6 06 05 01 73 5a 17 e2 0f 22
02 3a 80 18 71 38 2d 40 58 2c 45 00 ac 50 41 00
00 1e 1a 68 00 a0 f0 38 1f 40 30 20 3a 00 ac 50
41 00 00 1a 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 bf
Block 0, Base EDID:
EDID Structure Version & Revision: 1.3
Vendor & Product Identification:
Manufacturer: SAM
Model: 3677
Serial Number: ...
Made in: week 52 of 2017
Basic Display Parameters & Features:
Digital display
Maximum image size: 120 cm x 34 cm
Gamma: 2.20
DPMS levels: Off
RGB color display
First detailed timing is the preferred timing
Color Characteristics:
Red : 0.6826, 0.3085
Green: 0.2724, 0.6591
Blue : 0.1513, 0.0576
White: 0.3134, 0.3291
Established Timings I & II:
IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz
DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz
Apple : 640x480 66.666667 Hz 4:3 35.000 kHz 30.240000 MHz
DMT 0x05: 640x480 72.808802 Hz 4:3 37.861 kHz 31.500000 MHz
DMT 0x06: 640x480 75.000000 Hz 4:3 37.500 kHz 31.500000 MHz
DMT 0x08: 800x600 56.250000 Hz 4:3 35.156 kHz 36.000000 MHz
DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz
DMT 0x0a: 800x600 72.187572 Hz 4:3 48.077 kHz 50.000000 MHz
DMT 0x0b: 800x600 75.000000 Hz 4:3 46.875 kHz 49.500000 MHz
Apple : 832x624 74.551266 Hz 4:3 49.726 kHz 57.284000 MHz
DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz
DMT 0x11: 1024x768 70.069359 Hz 4:3 56.476 kHz 75.000000 MHz
DMT 0x12: 1024x768 75.028582 Hz 4:3 60.023 kHz 78.750000 MHz
DMT 0x24: 1280x1024 75.024675 Hz 5:4 79.976 kHz 135.000000 MHz
Apple : 1152x870 75.061550 Hz 192:145 68.681 kHz 100.000000 MHz
Standard Timings:
DMT 0x15: 1152x864 75.000000 Hz 4:3 67.500 kHz 108.000000 MHz
DMT 0x1c: 1280x800 59.810326 Hz 16:10 49.702 kHz 83.500000 MHz
DMT 0x55: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz
DMT 0x2f: 1440x900 59.887445 Hz 16:10 55.935 kHz 106.500000 MHz
DMT 0x53: 1600x900 60.000000 Hz 16:9 60.000 kHz 108.000000 MHz (RB)
DMT 0x3a: 1680x1050 59.954250 Hz 16:10 65.290 kHz 146.250000 MHz
( 3840x1080 at 120 Hz, 549.000000 MHz )
Detailed Timing Descriptors:
DTD 1: 3840x1080 119.973776 Hz 32:9 137.250 kHz 549.000000 MHz (1196 mm x 336 mm)
Hfront 48 Hsync 32 Hback 80 Hpol P
Vfront 3 Vsync 10 Vback 51 Vpol N
Display Range Limits:
Monitor ranges (GTF): 24-120 Hz V, 30-140 kHz H, max dotclock 600 MHz
Display Product Name: 'C49HG9x'
Display Product Serial Number: ...
Extension blocks: 1
Checksum: 0x20
Block 1, CTA-861 Extension Block:
Revision: 3
Underscans IT Video Formats by default
Basic audio support
Supports YCbCr 4:4:4
Supports YCbCr 4:2:2
Native detailed modes: 1
Video Data Block:
VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (native)
VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz
VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz
VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz
VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz
VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz
VIC 93: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
VIC 94: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
VIC 32: 1920x1080 24.000000 Hz 16:9 27.000 kHz 74.250000 MHz
VIC 33: 1920x1080 25.000000 Hz 16:9 28.125 kHz 74.250000 MHz
VIC 34: 1920x1080 30.000000 Hz 16:9 33.750 kHz 74.250000 MHz
VIC 95: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz
VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz
VIC 90: 2560x1080 60.000000 Hz 64:27 66.000 kHz 198.000000 MHz
Audio Data Block:
Linear PCM:
Max channels: 2
Supported sample rates (kHz): 48 44.1 32
Supported sample sizes (bits): 24 20 16
Speaker Allocation Data Block:
FL/FR - Front Left/Right
Colorimetry Data Block:
BT2020YCC
BT2020RGB
( HDMI 1.4 - Maximum TMDS clock: 300 MHz )
Vendor-Specific Data Block (HDMI), OUI 00-0C-03:
Source physical address: 1.0.0.0
Supports_AI
DC_36bit
DC_30bit
DC_Y444
Extended HDMI video details:
HDMI VICs:
HDMI VIC 1: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz
HDMI VIC 2: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz
HDMI VIC 3: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz
( HDMI 2.0 - Maximum TMDS clock: 600 MHz )
Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8:
Version: 1
Maximum TMDS Character Rate: 600 MHz
SCDC Present
Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding
Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding
HDR Static Metadata Data Block:
Electro optical transfer functions:
Traditional gamma - SDR luminance range
SMPTE ST2084
Supported static metadata descriptors:
Static metadata type 1
Desired content max luminance: 115 (603.666 cd/m^2)
Desired content max frame-average luminance: 90 (351.250 cd/m^2)
Desired content min luminance: 23 (0.049 cd/m^2)
YCbCr 4:2:0 Capability Map Data Block:
( 1920x1080 at 60.000000 Hz, 148.500000 MHz is 1/2 of maximum 297 MHz )
DTD 2: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz (1196 mm x 336 mm)
Hfront 88 Hsync 44 Hback 148 Hpol P
Vfront 4 Vsync 5 Vback 36 Vpol P
( 3840x1080 at 60 Hz, 266.500000 MHz corresponds to HDMI 1.4 and less of Intel Corp. limit 297 MHz )
DTD 3: 3840x1080 59.968497 Hz 32:9 66.625 kHz 266.500000 MHz (1196 mm x 336 mm)
Vfront 3 Vsync 10 Vback 18 Vpol N
Checksum: 0xbf
Warnings:
Display Product Serial Number is set, so the Serial Number in the Base EDID should be 0.
Failures:
Missing VCDB, needed for Set Selectable RGB Quantization to avoid interop issues.
EDID:
Base EDID: Some timings are out of range of the Monitor Ranges:
Horizontal Freq: 27.000 - 137.250 kHz (Monitor: 30.000 - 140.000 kHz)
CTA-861: Native progressive timings are a mix of several resolutions.
EDID conformity: FAIL
It's ok in theory because HD resolution commonly limited at 2K x 1K 1920x1080 @ 120 Hz,
4K x 1K (3840x1080) - 120 Hz / 2, 4K x 2K - 120 Hz / 4. But memory performances of notebook are absolute.
There is also Custom Resolution in IGCC.
Screen height 336 mm at 1080 pixel height gives very comfortable ppi for work.
Very fast implementation of NEXTGEN TV broadcasting unexpectedly leads to the appearance in every
home display with 4K resolution and HDMI input for testing.
The external display of the laptop can work as a single display.
Alx24.
Alx24
New Contributor II
Based on WMI/DMI programs give very detailed system and memory information.
Memory information in IGCC report text files
Single Module
- "Memory"
Physical Memory (Available):"2,34 GB"
Physical Memory (Installed):"8 GB"
Physical Memory (Total):"7,85 GB"
- "BANK 2"
Capacity:"8 GB"
Channel:"ChannelB-DIMM0"
Configured Clock Speed:"2400 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"SODIMM"
Interleave Position:"Noninterleaved"
Manufacturer:"859B"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"BLS8G4S240FSD.16FBD"
Serial Number:"C7000402"
Status:"Not Available"
Type:"Synchronous"
Multiple Modules
- "Memory"
Physical Memory (Available):"56.64 GB"
Physical Memory (Installed):"64 GB"
Physical Memory (Total):"63.31 GB"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller0-DIMM0"
Configured Clock Speed:"4000 MHz"
Configured Voltage:"1100 millivolts"
Data Width:"32 bits"
Form Factor:"DIMM"
Interleave Position:"Not Available"
Manufacturer:"Kingston"
Part Number:"KF552C40-16"
Serial Number:"263AA247"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller0-DIMM1"
Form Factor:"DIMM"
Serial Number:"263A9C9C"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller1-DIMM0"
Form Factor:"DIMM"
Serial Number:"2A2B5C59"
Type:"Synchronous"
- "BANK 0"
Capacity:"16 GB"
Channel:"Controller1-DIMM1"
Form Factor:"DIMM"
Serial Number:"252B5C56"
Type:"Synchronous"
Alx24.
n_scott_pearson
In theory, this should work just fine - and by my calculation, you might even be able to get to 60Hz. Now, this is based upon the laptop exposing the 'raw' HDMI 1.4 output of the processor. If the laptop includes a LSPcon IC (which converts from DP 1.2 to HDMI 2.0), you might even get to 120Hz.
Hope this helps,
