Hello, Recently I installed updates from windows
After the restart, my screen starts to flicker non stop
My laptop is Asus K45VM, with intel HD graphic 4000 and nvidia GT630M with windows 10 pro 64bit and i7 3610QM
What I have done to fix my problem were:
1. Updated both my Nvidia (version: 376.19) and Intel driver (version: 153343.4425)
none worked
2. I increase my brightness to max, somehow the flicker stops. But, if I have lower it down it will flicker again
Is this somehow related to refresh rate? If yes, I cant find the option both in intel and nvidia control panel
Some help please
- Tags:
- Drivers
Hello WilliamKho,
Try running Windows Updates to have your systems up-to-date, then try uninstalling the Intel® HD Graphics with this method;
- Open the Device Manager using the steps provided for your operating system:
- Expand the Display Adapters section.
- Find the Intel Graphics Driver. The driver can also be called the Intel® Graphics Media Accelerator Driver (Intel® GMA Driver).
- Right click Intel Graphics Driver and select Uninstall.
- Select the check box Delete the driver software for this device.
- Reboot the computer after uninstall process has finished.
- Install the driver .4425 one more time, https://downloadcenter.intel.com/download/25977/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-33-?product=81499 Download Intel® Graphics Driver for Windows® 10 and Windows 7*/8.1* [15.33] using this method http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html Manually Install an Intel® Graphics Driver in Windows® 10 and Windows...
If you go to the Intel® HD Graphics Control Panel then Display, you should see the refresh rate.
Let me know how that goes.
Amy.
/thread/109063 WilliamKho, were you able to follow the suggestion mentioned? Does the issue persist?
Amy.
The problem was fixed when I installed the latest windows update
Thank you for the assistance
That is really good to hear!
If you need further assistance let us know.
Amy.
![](/skins/images/5954227144809D6985E57E08C591D426/responsive_peak/images/icon_anonymous_message.png)
