22654 Discussions
Windows 10 lagging\slow when HDR is enable
ArielD
I have lenovo m720q  connected to my OLED C8 TV with the following configuration:
intel i5-9400T
intel UHD 630
The PC connected with DP to HDMI active adapter that support 4k60hz HDR(club3d 1080) with HDMI 2.1 cable.
I can enable HDR but when I do it slow down my PC like when I click on start menu - it lagging (not smooth like when HDR off), when I play video the video isnt smooth.
I have the latest version of intel graphic driver, bios, chipset and lenovo other drivers.
windows is updated to the latest version: windows 10 21H2
hope someone can help
Alberto_R_Intel
ArielD, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
Is this a new computer?
When did you purchase it?
Was the HDr feature working fine before on this specific machine?
If so, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
ArielD
HI Alberto,
This is a 1 year old computer still in warranty
I purchase it 1 year ago
I tried to enable HDR for the first time so there was no HDR before.
no recent hardware\software changes
the problem happens at home
See the SSU File below
waiting for your help,
Ariel
Alberto_R_Intel
Hi ArielD, Thank you very much for providing that information and the SSU report.
Since you are trying to use the HDR feature for the first time, it is important first to confirm how to enable HDR and also if the computer complies with the system requirements to use it. In the following link, you will find important details about that matter where you can verify that information including the resolutions supported. Even though it is related to a different Intel® graphics controller, it also applies to newer generations:
https://www.intel.com/content/www/us/en/support/articles/000032112/graphics/graphics-for-7th-generation-intel-processors.html
In that same link, you will find a PDF presentation also including additional facts about HDR. Just in case, here is the link:
https://www.intel.com/content/dam/support/us/en/documents/graphics/HDR_Intel_Graphics_TechWhitePaper.pdf
One of the main things to check is the type of port being used, as you can see in the link, not all of the HDMI versions are supported, it is required for that port to be HDMI2.0a and the DisplayPort needs to support HDCP2.2.
You can always confirm those specifications on your computer by getting in contact directly with Lenovo Support since that information is not shown in the specifications provided by Lenovo:
https://psref.lenovo.com/syspool/Sys/PDF/ThinkCentre/ThinkCentre_M720_Tiny/ThinkCentre_M720_Tiny_Spec.pdf
Once you do that, if the machine complies with all the requirements and still Windows is lagging while trying the use HDR, please confirm with them if the BIOS version currently installed is the latest one and also you can try to install their latest graphics driver, which is version 30.0.101.1122, that was tested an validated and contains all their customizations to meet the functionality advertised to it:
https://pcsupport.lenovo.com/cr/en/products/desktops-and-all-in-ones/thinkcentre-m-series-desktops/m720q/10t7/downloads/driver-list/component?
name=Graphics%20Processing%20Units%20%28GPU%29%20and%20Server-AI%20Accelerators
Gigabyte Support:
https://support.lenovo.com/us/en
Once you get the chance, please let us know the results.
Albert R.
Alberto_R_Intel
Hello ArielD, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello ArielD, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
