22655 Discusiones
Windows 8.1 or Windows 10 after update graphic, black screen on my Intel Nuc DN2820FYKH, monitor acer G245HQ, but only on Windows 7 Works
MCan
Principiante
18.510 Vistas
Best Intel,
I have a problem of update:
Graphics: Intel® HD Graphics Driver for Intel NUC 10.18.10.3621 (Latest)
When I install Windows 7 64bit on my DN2820FYKH and update this Graphics software just works normally and shows resolution to 1920 x 1080.
But if I install Windows 8.1 64 bit graphics software update after I get black screen on my monitor screen. also restart does not work ...
Also, Windows 10 I have given windows microsoft feedback, but no screen after update of graphics software from DN2820FYKH.
I also installs latest chipset version. But I think the monitor is G245HQ driver problem. so hopefully that intel graphics software is an update or fix it. It is unfortunate that only Windows 7 64bit does work.
Thanks You if reply.
Cable: HDMI
My screen model: G245HQ
My computer hardware: DN2820FYKH
SSD: Samsung 850 PRO 128GB ATA Device
RAM: 4GB PC3L 12800 CL11 204 - pin SODIMM Model: KVR16LS11 / 4
my latest bios update also:
BIOS Version / Date Intel Corp. FYBYT10H.86A.0047.2014.1224.1147, 12/24/2014
0 kudos
25 Respuestas
MCan
Principiante
9.013 Vistas
See here from monitor driver download for Windows 7, Vista
http://www.acer.be/ac/nl/BE/content/drivers Drivers en handleidingen downloaden | Officiële Acer-site
But I can not install on Windows 8.1 or Windows 10, its say not signed etc...
Hopefully intel will that software graphics fix it this driver monitor for new windows 8.1 or windows 10 or not ?
Thanks....
Jose_H_Intel1
Empleados
9.013 Vistas
Hi Memo, I have some questions:
Are you using a straight high quality HDMI cable?
How is the monitor detected in Device Manager (Windows* 8.1)?
Please share your http://www.intel.com/support/graphics/sb/cs-009476.htm Intel® Graphics Driver Report
MCan
Principiante
9.013 Vistas
Hi Joe Intel,
Yes my HDMI cable version is 1.4a hdmi, but I do no know what about straight cable?
When I Windows 8.1 was installed think I monitor device was non-pnp hardware dedected. but I can not install new intel because black screen I can not see...
But I like this picture from internet and resolution same, and I can not chose resolution on windows 8.1 without driver instal intel :
But my only work is on windows 7 64bit so here information :
Intel(R) HD Graphics
Report Date: Wednesday, January 14, 2015
Report Time [hh:mm:ss]: 12:06:43 PM
Driver Version: 10.18.10.3621
Operating System: Windows* 7 Professional(6.1.7601)
Default Language: Dutch (Belgium)
Installed DirectX* Version: 11.0
Supported DirectX* Version: 11.0
Shader Version: 5.0
OpenGL* Version: 4.0
OpenCL* Version: 1.2
Physical Memory: 3984 MB
Processor: Intel(R) Celeron(R) CPU N2830 @ 2.16GHz
Processor Speed: 2166 MHz
Vendor ID: 8086
Device ID: 0F31
Device Revision: 0E
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics
Video BIOS: 1015.0
Current Resolution: 1920 x 1080
* Other names and brands are the property of their respective owners.
And windows 7 are working on new intel driver but it is weird xD see picture: and here dxdiag txt download and intel txt information...
MCan
Principiante
9.013 Vistas
Is there anyone?
ROBERT_U_Intel
Empleados
9.013 Vistas
Hi Memo
Do you have access to a different display you could test?
Also, could you verify the issue with the latest driver available here
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24593 64 bit version
Robert
MCan
Principiante
9.013 Vistas
other my TV hdmi will work but not my monitor G245HQ on windows 8.1 or 10
But I try again you give link so hope will work , but how did you find this driver for my intel NUC ? let me know please . 🙂
MCan
Principiante
9.013 Vistas
And here new for Intel NUC https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=24391 Intel® Download Center but what is better ?
https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24593 Intel® Download Center
15.33.32.64.4061 (Latest)
Intel® HD Graphics Driver for Windows* 7/8/8.1-64-bit
or
Graphics: Intel® HD Graphics Driver for Intel® NUC
15.33.32.4061 (Latest)
I think 64 bit is better maybe? or is 32 bit is stable ?
I can not chose
MCan
Principiante
9.013 Vistas
Its again not work in windows 8.1 64 bit black screen I have installed both driver but black screen but other TV hdmi will see but not my monitor
But I will give information dxdiag on windows 8.1 without intel driver...
Vendor ID: 0x1414
Device ID: 0x008C
SubSys ID: 0x00000000
Revision ID: 0x0000
ROBERT_U_Intel
Empleados
9.013 Vistas
Hi Memo
You have Windows 8.1 64bit installed on your system. You need the 64 bit version of the graphics driver. The versionhttp://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24593 15.33.32.64.4061 I posted the link for is the latest version for the version of Intel HD graphics on your NUC.
I would recommend installing this version.
Robert
MCan
Principiante
9.013 Vistas
Hi Robert
I have already installed and still does not work I do not know why windows 7 works, but I'm going to give information of windows 7 installed with without graphic driver, its is weird on windows 7 without driver is VGA ? but my cable is HDMI connected...thats why work if I install driver intel?
Vendor ID: 0x8086
Device ID: 0x0F31
SubSys ID: 0x20558086
Revision ID: 0x000E
ROBERT_U_Intel
Empleados
9.013 Vistas
@ Memo, According to the latest DXDiag report you posted you do not have the Intel HD Graphics driver installed. Please downloadhttp://downloadmirror.intel.com/24596/a08/win64_153614.zip this driver, extract it to a folder on your desktop, and follow the steps below exactly to install the driver.
1. Login to your system with administrator privileges
2. Open Control Panel
3. Open Device Manager
4. Click on "Display adapters"
5. Double click "Intel HD Graphics"
6. Click on the "Driver" tab
7. Click on "Update Driver" button
8. Click on "Browse my computer for driver software"
9. Click on "Let me pick from a list of device drivers on my computer"
10. Click on "Have Disk" button
11. Click "Browse"
12. Navigate to the folder that you unzipped the Intel HD Graphics driver to
13. Navigate to the Graphics sub-folder
14. Double click the igdlh64.inf or igdlh.inf file <-- depends on if you have 32 or 64 bit OS</span>
15. Click "OK"
16. Click "Next", Driver should now be installing.
17. If successful, click "Close", Reboot.
Robert
MCan
Principiante
9.013 Vistas
Can Not instal see picture with dxdiag...
MCan
Principiante
9.013 Vistas
MCan
Principiante
9.013 Vistas
So its not work on windows 8, its is really driver monitor problem, I see my monitor acer G245HQ only have windows 7 driver so not windows 8... that why problem I think...
you can see acer support driver... But I go maybe ask to acer support for windows 8 question.
MCan
Principiante
9.013 Vistas
So what now? can I install windows xp 64? but does not because of SSD hard drive? Windows 7 is slow, I want to install windows xp, anyone know how?
MCan
Principiante
9.013 Vistas
I have question, which have language is graphics intel driver written ? C# or C++ ? Can I maybe self fix it? how can I learn? please answer.
Jose_H_Intel1
Empleados
9.013 Vistas
This is the list of supported operating systems for Intel® NUCs:
http://www.intel.com/support/motherboards/desktop/sb/CS-034034.htm Intel® NUC — Supported Operating Systems
So, the cable that you are using is HDMI to HDMI?
Did you try installing all Windows* updates?
MCan
Principiante
9.013 Vistas
Yes my hdmi is to hdmi but my LED TV hdmi will work but NOT my MONITOR ACER G245HQ working...
I have again try all windows updates installed...
and black screen
Only windows 7 works,
Windows 8.1 works NOT but my other TV LED sony tv will works but not my monitor , have you understand ....?
MCan
Principiante
9.013 Vistas
Nobody somethings problem solved ?
MCan
Principiante
8.769 Vistas
Acer will not answer , I think there not solving, So I go wait for windows 10 problem fixing maybe I have asked on feedback , hope fixed, if not then intel problem or monitor problem...
Responder
