22690 Discusiones
Your computer does not meet the minimum requirement for installing the software.
JTorr12
Novato
6.952 Vistas
I really need your help, I tried to update my graphics driver but it keeps on getting this message.
"Your computer does not meet the minimum requirement for installing the software."
I hope you could help me with this one. My system details are as follows:
Operating System: Windows 7 Professional 64-bit (6.1, Build 7601)
Language: English
Bios: Default System BIOS
Processor: Intel(R) Atom(TM) CPU D2500 @ 1.86GHz (2CPUs). ~1.9GHz
Thank You
0 kudos
16 Respuestas
JTorr12
Novato
4.860 Vistas
BUMP!!! seems no one knows how to solve this problem
DArce
Colaborador Valioso III
4.860 Vistas
JTorr12
Novato
4.860 Vistas
Thank You for the reply. But I still get the error message.
DArce
4.860 Vistas
Please post the graphics report generated in your system using the instructions on the following URL:
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics | Intel (R) Graphics Driver Report
In addition, copy paste also the dxdiag report from that same system.
JTorr12
Novato
4.860 Vistas
Johnny_Y_Intel
Empleados
4.860 Vistas
There is no 64bit drier for GMA 3600
JTorr12
Novato
4.860 Vistas
I cant find the intel graphics tab
Johnny_Y_Intel
Empleados
4.860 Vistas
Of course you cannot find intel graphics tab because you have not instlled graphics driver. And unfortunately, there is no 64bit driver for Intel GMA 3600, so just one suggestion: Install Windows 7 32bit
JTorr12
Novato
4.860 Vistas
sir my processor is Intel(R) Atom(TM) CPU D2500. Is it equivalent to GMA 3600?
Johnny_Y_Intel
Empleados
4.860 Vistas
JTorr12
Novato
4.860 Vistas
JCHOI22
Principiante
4.860 Vistas
this computer does not meet the minimum requirements for installing the software
I also have this problem. what kind of driver should I install?
My spec/
WINDOW 7 PRO 64 bit
INTEL CORE i7-4770K CPU @ 3.50 GHz
NVIDIA GeForce GTX 660
SYSTEM BIOS
DArce
4.860 Vistas
Jay123, you need to confirm if your system supports switchable graphics or not with your motherboard or computer manufacturer. If not, then by installing the GTX video card in the system, the integrated video display of the processor is disabled, so the driver is not required and cannot be installed.
Anyhow, the generic driver for the video controller in the i7-4770k is posted here:
https://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/22842/a08/Win64_15319.exe&lang=eng&Dwnldid=22842&DownloadType=%0a%09%09%09%09%09%09%09Drivers%0a%09%09%09%09%09%09&OSFullname=Windows+7+(64-bit)*
N4IOS
Principiante
4.860 Vistas
the links dont work they just bring you back to this page
MJun1
Principiante
4.860 Vistas
Same issue happened. Solved like this:
Removed "Display Driver"-item in device manager list with "uninstalling drivers" tick
Then
1)Start booting WIndows with continuously pressing F8 right after POST(same as if you want to go to "Safe Mode")
2)Select "Disable driver signature enforcement"
3)Let Windows find some vga-device(it should not look for drivers, just install some vga device without drivers right after Windows stops loading)
4)Try to install Your drivers.
Responder
