23818 Discussions
change user name
vasilis
Hello  i  would  ask  you  if  there  any  offical  email  support  from  intel  and  i  can  change  user  name  profile
AlHill
Look under your settings, personal, display name.
Is that what you are looking for?
Doc
vasilis
intel  has  any  official  email  support?driver  assistant  find  a  nwer  version  of  LNC  (something  like  that)  but  failed  to  install  it
n_scott_pearson
No. Support is provided through this support community, via chat service (during office hours for Pacific TZ) or via phone (during office hours for the TZ of the geo support office).
Here are pages where you can lookup contact information, including local phone numbers, by geography:
In many cases, there are Customer Support folks who will be able to communicate with you in your native tongue.
Are you aware that you can enable email notification in this support community? With this enabled, you can receive an email letting you know that someone has responded to your posts, etc.
vasilis
thank  you.Do  you  know  anything  about  the  issue  with  intel  support  assistant?
n_scott_pearson
Which issue (there are a number of issues being tracked)?
....S
vasilis
intel  driver  assistant  find  a  new  nfc  driver  something  like  that  but  failed  to  install  it
n_scott_pearson
Sorry, I would have to know exact name for this package. As well, if there is log file from this item's attempted installed, please include it in a response.
What I suggest you do is:
  1. Go into Task Manager , select More Details and then stop the services named DSAService, DSAUpdateService and Intel Driver and Support Assistant Tray.
  2. Place copies of all of the files in folder C:\ProgramData\Intel\DSA into a ZIP file.
  3. Attach this ZIP file to a response post. Use the Drag and drop here or browse files to attach dialog just below the edit box.
  4. Reboot to get these services running again.
vasilis
vasilis
Sorry  my  delay  responce.Sometimes when installing newer version DCH drivers(with  intel  driver  assistant  utility) and after rebooting reapears the window for installing new driver,is a bug?I  have  asus  rog G731GV.iNTEL  official support  told  me  that  the  utility  is  designed  for  intel  products  and  it  is  better  to  install  original  drivers  from  company
