23818 Discussions
cs2 crashes with irisxe
AM777
With iris xe on a 12500h Asus laptop with 16gb ram, I am able to get reliable 60fps on low settings and low resolution
However, the game crashes frequently (once every couple hours). Can you please try this and let me know if there is a solution possible?
Alberto_R_Intel
Hello AM777, I just received an update on this matter.
There is a new driver available on our official website, version 31.0.101.5186/31.0.101.5234. Please try a clean installation of that driver following the instructions in the links below and once you get the chance, please let us know the results:
Driver:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html?wapkw=12500h
Albert R.
Alberto_R_Intel
Hello AM777, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
AM777
Hello Albert,
I haven't been able to try your suggestion in detail yet. I will get back as soon as I get a chance to try it.
AM
Alberto_R_Intel
Hello AM777, Thank you for your answer.
No problem at all, take your time and once you get the chance, please let us know the results.
Albert R.
AM777
Hello Albert,
I was able to reproduce the crash again with the latest drivers that you recommended, so this issue still continues.
AM
Alberto_R_Intel
Hello AM777, Thank you very much for your reply.
We are sorry to hear the issue persists. We will continue working on this scenario and provide a response as soon as possible.
Albert R.
Alberto_R_Intel
While we are still working on this scenario, could you please try the steps below one by one and note what was the result:
  • Turn off cpu virtualization in Bios
  • Disabling e-cores
  • Disabling multicore rendering in the game settings ==> didn't found this option in game
  • System repair
    • sfc /scannow
    • Dism.exe /online /cleanup-image /restorehealth
  • Disable CPU boost in BIOS
  • Change SVID to Intel Fail safe in BIOS
Test PC settings in BIOS:
  • MCE (enhanced multi-core performance): disabled,
  • Active turbo ratios: auto,
  • Dynamic Vcore: +0.005V (as per article 000096305),
  • XMP: on
  • also tested on stock BIOS settings
The game is set to LOW in video settings - no issues ever happen while testing.
List of options that can be used to launch game: https://eloboss.net/blog/csgo-launch-options
Albert R.
Alberto_R_Intel
Hello AM777,
Albert R.
AM777
Hello Albert
I've made halfway through the suggestions:
  • Turn off cpu virtualization in Bios - Turned off virtualization / VT-d
  • Disabling e-cores - Don't see any such options in BIOS. I have added '-threads 5' to game launch options which seems to have limited game process to P-cores
  • System repair - To be tried
    • sfc /scannow
  • Disable CPU boost in BIOS - No such option in the BIOS
  • Change SVID to Intel Fail safe in BIOS - No such option in the BIOS
  • XMP: on
Don't see any of the above in BIOS settings
The game is set to LOW in video settings - no issues ever happen while testing - will try with low
Whatever I have tried so far, I still got couple of crashes. I need to try few more of the suggestions, will post another update when I do those.
AM
a1one
I get 60fps on 1080p low settings how are you not getting it and on 1280x960
I get 70-80 fps
AM777
With recent game and driver updates, I am no longer seeing crashes as frequently (maybe once in 2 weeks or so).
I believe it was recent game updates that fixed issues for me.
Also on low setting I do get ~50-60 fps at 1080p, this is again an improvement that seems to have come with recent updates. Earlier FPS used to drop to 40 in some situations.
NormanS_Intel
Hello AM777,
It is great news that the recent updates have enhanced your gaming performance. I wish you a smooth and enjoyable gaming session. As a result, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Norman S.
