23075 Discussions
driver xx.xx.15.4251
GelsonJr
I downloaded Plants vs zombies garden warfare 2 from xbox gamepass and when i tried to run the game i recived a error mensage that says "Detected intel driver version 30.0.101.1338 1/20/2022 00:00:00 the recommended driver version is xx.xx.15.4251 or later please uptade your drivers in (intel website) before playing the game
My pc:
Dell inspirion 3501
11th Gen Intel(R) Core(TM) i5-1135G7 @ 2.40GHz 2.42 GHz
Intel iris xe graphics card
AlHill
Update the driver:
https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html?
silvasaks
Processador Intel(R) Core(TM) i5-1035G1 CPU @ 1.00GHz 1.19 GHz
RAM instalada 8,00 GB (utilizável: 7,79 GB)
ID do dispositivo ACC6B4EE-B6F8-40AA-9D35-2351D80E9C45
ID do Produto 00342-43228-37553-AAOEM
Tipo de sistema Sistema operacional de 64 bits, processador baseado em x64
Caneta e toque Nenhuma entrada à caneta ou por toque disponível para este vídeo
zain3
brother can you please send me a link for my specific laptop pleaseeee its showing the
its an
hp elitebook 840 G3
i5-6300u
8gb ram
intel(R) HD Graphics 520
robby2
i downloaded need for speed payback and told me i required an intel driver version xx.xx.15.4251 my pc is hp elitebook 840 G3    Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz 2.40 GHz     GPU is intel HD graphics 520   IMG20231028092108.jpg
AlHill
@robby2   This is the latest and likely last driver for your processor, which is no longer supported:
https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html
If this does not work, you are out of luck.
robby2
hey it did not work still what else could it be
AlHill
What could it be?  Your game wants a higher level graphics driver than is available for your device.
If you are a desktop, get a nvida or amd card.
If not, get newer hardware.   I would suggest an 11th gen system or later.
osama-2003
how i can fix this problem ?
AlHill
@osama-2003   Your hardware either supports the driver, or it does not.
If you read the thread, you have the answer for either situation.
soccerdude2060
My laptop: LENOVO 81WB
BIOS
Version
DXCN28WW                                   Hi I just got need for speed heat and when I tried to play it it came up with the error people        mentioned above and I don't know what driver to install. (I put my laptop type on the left).
Date
11/24/2020
MOTHERBOARD
Manufacturer
LENOVO
Model
LNVNB161216
Version
SDK0J40700 WIN
Edition
Microsoft Windows 11 Home (64-bit)
Version (Build)
23H2 (10.0.22631)
n_scott_pearson
Latest graphics driver package for your 6th gen processor can be downloaded from here: https://www.intel.com/content/www/us/en/download/762755/intel-6th-10th-gen-processor-graphics-windows.html.
Hope this helps,
Sigma1
 PROCESSOR: Intel(R) Core(TM) i5-3570S CPU @ 3.10GHz 3.10 GHz
Sigma1_0-1734793679448.pngRAM:8GB RAM
n_scott_pearson
The latest - and last - GFX driver package for your (long discontinued) 3rd gen processor is v15.33.53.5161. This package installs GFX driver v10.18.10.5161 and thus it should alleviate this Warning. You can download this package from here: https://www.intel.com/content/www/us/en/download/18606/intel-graphics-driver-for-windows-15-33.html.
Hope this helps,
CarlosPaz
I downloaded Plants vs Zombies 2, but it appears an error message asking for "the recommended driver version is xx.xx.15.4251 or later", as people above has said.
My specs: HP Pavilion Intel Core i7 9th Gen
RAM: 8GB
Windows 10 / 20H2 (64 bits)
Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz 2.59 GHz
JAb231004
Did you solved the problem?
Dunamis765
im having the same problem with mine when i trie playing pvz gw 2 i played it before and it worked fine but now its not working for me i have 3 hours in the game what do i do
