sendo que essa es a configuração:
System Information
Time of this report: 5/13/2019, 15:36:54
Machine name: DESK
Operating System: Windows 8.1 Pro 32-bit (6.3, Build 9600) (9600.winblue_ltsb.160812-0914)
Language: Portuguese (Regional Setting: Portuguese)
System Manufacturer: GBT___
System Model: AWRDACPI
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Celeron(R) CPU 2.66GHz, ~2.7GHz
Memory: 1280MB RAM
Available OS Memory: 1264MB RAM
Page File: 936MB used, 1798MB available
DirectX Version: DirectX 11
Display Devices
Card name: Adaptador de Vídeo Básico da Microsoft
Manufacturer: (Tipos padrão de vídeo)
Chip type: Intel(r)865G Graphics Chip Acce
DAC type: Intel Corporation
Device Type: Display-Only Device
Alguém poderia me ajudar por favor?
Please download the 32 bit version of this driver and try to install it: https://downloadcenter.intel.com/download/23339/Intel-HD-Graphics-Driver-for-Windows-8-1-for-Intel-D...
Leon
THANK YOU! Well, I did the procedure. I downloaded the 32 bit and tried to install. but when performing the setup an error message appears saying that the system does not meet the minimum requirements for the installation of the software. WHAT CAN IT BE?
- I have not enough information about your system. Please download Intel System Support Utility (SSU) https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- . Run this utility, check Everything and then press Scan. The save the generated report and attach to your post.
- I have to admit that I don't know the GBT (manufacturer of your computer). May be from the SSU report I'll know what is the motherboard model at least.
Leon
Hi @Cdeje1
- Reading the SSU report, I could see that your PC is equipped with Gigabyte 8I865GME-775 motherboardhttps://www.gigabyte.com/Motherboard/GA-8I865GME-775-rev-1x#sp . This motherboard is outdated and has very limited support. All drivers you can find here: https://www.gigabyte.com/Motherboard/GA-8I865GME-775-rev-1x#support-dl-bios . The latest VGA driver for Windows XP 32bit was released in May 2006. There is no support for Windows 8.1. The Microsoft Basic Adapter Driver is the best what you can have.
- You have not installed any Video Adapter Card in the AGP slot which could improve the graphics performance.
- The RAM memory on this board is limited only to 2GB, while in fact you can use 1.25GB only.
- Many current application will not run on this board. So, either you agree with this status or buy a new and updated computer.
- Sorry, I couldn't help more.
Leon
