22828 Discussions
graphic resolution to 1920x1020
heyhey
hi I would like to change my graphic resolution to 1920x1020, and wondering if it's possible with my laptop. i have attached my computer's details.
Thanks!
AlHill
What matters is the maximum physical resolution of your laptop, which is not likely to go that high.
To verify, download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
[Windows 11 is the new Vista]
heyhey
Hi
Thank you for the quick reply!
Please see attached 🙂
AlHill
Sorry, but the bad news is that your laptop display screen is 1366 x 768.
However, if you were to add an external monitor that supported 1920x1024 (or greater), your intel/nvidia graphics would certainly support the resolution you want.
