23280 Discussions
how can i install intel graphics control panel without microsoft store?
MFara7
hi,
i have ThinkCentre M920q i've install the latest driver ' Intel ® Graphics Driver Version:"26.20.100.6860".
and i can't see the driver control panel.
I read a little about it and realized that the app should be downloaded through the Microsoft store, but the problem is that I do not have access to the store through the firewall in the workplace. How can I install the application?
n_scott_pearson
Good question! I want to know the answer too.
Alberto_R_Intel
MFara7, Thank you for posting in the Intel® Communities Support.
In reference to your inquiry, just to let you know, all the Intel® Graphics drivers from version 6444 or higher are considered Intel® DCH graphics drivers, like in this case version "26.20.100.6860" that you are currently using.
As you mentioned, the Intel® Graphics Control Panel is no longer bundled with the DCH driver and is automatically downloaded from the Internet.
So, for this specific scenario, the next thing to do will be for you to get in contact directly with the IT administrator of your company for him/her to disable the Firewall in the workplace for you to be able to download the Intel® Graphics Control Panel from the Microsoft* store.
Alberto R.
Under Contract to Intel Corporation
MFara7
Alberto R, Thank you for your answer, I asked my IT administrator the workplace,
the answer was that you can not open access to Microsoft* store it because there are also Apps that can be installed that is unwanted.
Is it really not possible to install Intel® Graphics Control Panel in a different way?
thanks
LeonWaksman
With the DCH driver 26.20.100.6860 you suppose to have downloaded and installed the Intel Graphics Command Center which is replacing the Intel Graphics Control Panel. You should find it in the Start Menu and also on Taskbar (in the hidden icons area).
Leon
MFara7
LWAKSMAN, Thanks gfor your reply, i can't find the Intel Graphics Command Center are you sure it's installed with the drivers?
where can i find it?
thanks
LeonWaksman
  1. I have now installed the latest Intel Graphics DCH Driver version 26.20.100.6912. The Intel Graphics Command Center is a part of this driver package. Please read the Release Notes: https://downloadmirror.intel.com/28888/eng/ReleaseNotes_100.6912.pdf . If I'm not wrong, it was already included in the previous release of this driver.
  2. See the attached video to see where you should look for it.
Leon
Alberto_R_Intel
MFara7, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
A Contingent Worker at Intel
Alberto_R_Intel
MFara7, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
