Объявления
22742 Обсуждение
how to rotate displays while using combined displays
Mermilio
Начинающий
5 900Просмотр.
Greetings.
Setup: Dell laptop with Intel(R) Iris(R) Xe Graphics plugged into the Dell USB-C docking station. 2 monitors plugged into the docking station. Driver v. 31.0.101.3959
I have two displays in portrait mode sitting side by side to create a large square desktop. In extended desktop mode, I set one to Portrait, and the other to Portrait (Flipped). I do this as the monitors have thin borders on the tops and sides, but thick borders along the bottom. By setting them Top<>Top I minimize that border.
However, when I go to combine the displays they are always set to the same orientation. Forcing me to arrange them Top<>Bottom and have a large border between the screens.
Can this be resolved?
Метки (1)
0 баллов
9 Ответы
Jean_Intel
Сотрудник
5 869Просмотр.
Hello Mermilio,
We understand that you are having issues when combining the displays.
To better understand your issue, please provide me with the following:
  • Take a picture of the two displays on the combined mode showing the problem.
  • Provide me with the Monitor model you have.
  • Create a report using the two following apps:
    • Intel®️ System Support Utility (Intel®️ SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Сотрудник
5 836Просмотр.
Hello Mermilio,
I hope you are doing fine.
Jean O.
Mermilio
Начинающий
5 833Просмотр.
Jean,
Attached you'll find the Screen shots, as well as photos showing the issue.
The monitors are Dell P2422H (Qty: 2)
Thank you.
Jean_Intel
Сотрудник
5 826Просмотр.
Hello Mermilio,
Thanks for your response.
Jean O.
Jean_Intel
Сотрудник
5 799Просмотр.
Hello Mermilio,
Thank you for waiting for a response.
After reviewing this matter, we have confirmed that this is an expected behavior. We have a guide that shares the steps on how to combine the displays.
Jean O.
PeteRepeat
Начинающий
3 302Просмотр.
So it seems that Intel are confirming that you can't combine displays properly if one is flipped? It seems a common problem across board for Intel combine. Can you check if the engineers plan to resolve this so a flipped screen stays flipped when combined. I see the standard reply is to ask for information, but it seems this is not hardware specific and a limitation of intel command centre ability to properly combine displays?
Jean_Intel
Сотрудник
5 754Просмотр.
Hello Mermilio,
Jean O.
Jean_Intel
Сотрудник
5 721Просмотр.
Hello Mermilio,
We hope you are doing fine.
Best regards.
Jean O.
emc333
Начинающий
118Просмотр.
Hello from outer space, this is issue is still valid, when I try to combine two flipped monitor, (one is flipped, other one is reverse flipped), intel combine them both of them is flipped in same direction but in this case thicker bezel area is middle of the monitor. Come on Intel, you could do this small issue, just remember the direction of the monitors in windows setting.
Ответить
