22644 Discussões
ideapad 300 Chrome graphic issue
LLore3
Principiante
4.193 Visualizações
I recently bought an ideapad 300 and it's a great machine. The only issue I came across is that the Chrome browser shows some graphics error (seen in picture)Chrome graphic issue
This behaviour is quite common - however, a simple mouse selection or even hovering over the obstructed area is enough to make the screen work again. This only happens with Chrome (I've seen people with similar Firefox issues), and sometimes the entire screen becomes unstable and freezes. In these situations, the notification "chrome.exe was blocked from using graphic.." used to pop up, but with the Windows 10 anniversary update and some settings tweaking, I was able to revert that. Sometimes the problem occurs but solves itself within fractions of a second (and actually that just happened now). I tested the matter using a hangouts screensharing and it picked the problem too.
I have also seen people with HP computers having similar problems, even with the same graphics card/processor combination. Any suggestions are warmly welcome.
Data:
ideapad 300
Intel i5 6200
8GB RAM
Intel graphics 520 driver 20.19.15.4352
15 Respostas
Funcionário
2.470 Visualizações
Hello lorenzo-flldr:
"The notification "chrome.exe was blocked from using graphic.." used to pop up, but with the Windows 10 anniversary update and some settings tweaking, I was able to revert that."
What exactly did you do?
I noticed that you have an older driver version, so let's try updating it. See here for the latest driver version https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88355 https://downloadcenter.intel.com/download/26228/Intel-Graphics-Driver-for-Windows-10-and-Windows-7-8-1-15-40-?product=88355, and I recommend using this method for the installation http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html http://www.intel.com/content/www/us/en/support/graphics-drivers/000005629.html.
Let me know how it goes.
Amy.
LLore3
Principiante
2.470 Visualizações
I switched the conservative morfological anti alising setting to off, as it was recommended even for some people with Firefox issues, and some other things I don't quite remember but seem not to have worked. I am updating the driver now (at the time of the post on Lenovo forum, it was the latest).
LLore3
Principiante
2.470 Visualizações
Just used the method, driver is up to date.
Funcionário
2.470 Visualizações
Does the issue persist with version .4501?
One more thing, could you please check what is the version of Google Chrome you have installed?
Amy.
LLore3
Principiante
2.470 Visualizações
Yes, and it seems to happen in "batches", that is, when it happens once, it's very likely to happen twice and so on.
I forgot the chrome version!
Chrome 53.0.2785.116 m (64-bit)
Funcionário
2.470 Visualizações
Have you tried using a different browser?
By any chance, have you noticed what triggers the corruption?
Try changing the setting for the hardware acceleration in Chrome, Go to Menu > Settings > Show advanced settings > Under System, uncheck "Use hardware acceleration when available" and restart Chrome.
We have several systems with Intel® HD Graphics 520, but we haven't experienced this behavior. We are running Intel® HD Graphics version .4501.
Amy.
LLore3
Principiante
2.470 Visualizações
I use firefox without any problems;
The problem doesn't seem to have a trigger; it looks random.
I'll run the .exe file to update again
LLore3
Principiante
2.470 Visualizações
.exe wasn't compatible with computer (?)
Funcionário
2.470 Visualizações
The .exe version is the same version that the .zip version, they just have different methods of installation.
This behavior is strange, so we need to make sure that your system is up to date. Please, try updating the following components;
Amy.
Funcionário
2.470 Visualizações
/thread/106743 lorenzo-flldr,
I am following up your thread; were you able to follow the suggestion mentioned above? The recommendation should help addressing this issue, so please give it a try and let me know that goes.
Amy.
LLore3
Principiante
2.470 Visualizações
Hello, I didn't try the BIOS update because I don't want to risk it. Other software is up to date, and the issue have not appeared since
Funcionário
2.470 Visualizações
That is good to hear. If the issues persists, please let me know.
Amy.
LLore3
Principiante
2.470 Visualizações
So far, no chrome issues. However, yesterday the whole screen froze, but in a way that is different from the issue commented here. I believe that's an unrelated event that came up, since I was using the pc quite vigorously at the time (video call, screen share, double monitors..... it was a busy day). Let's wait and see
Funcionário
2.470 Visualizações
Alright, keep me posted.
Amy.
Funcionário
2.470 Visualizações
I wanted to check on your thread; how the driver working? Have you experienced the issue?
Amy.
Responder
