- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
i5-11300H (Iris Xe Graphics)
OS: Win10 20H2
Driver: latest 27.20.100.9316 (3/3/2021)
you can test in dxva checker (https://bluesky-soft.com/en/DXVAChecker.html)
image broken with direct3d11 discard, fine with direct3d11 flip mode
i think problem is in driver. please test the attached file.
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
To better assist you, can you please provide the following reports and information:
Intel® System Support Utility (Intel® SSU)
Instructions
- Open the application and click on "Scan" to see the system and device information
- By default, Intel® SSU will take you to the "Summary View".
DXDIAG
Instructions
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
Intel® Graphics report
Instructions link:
https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html
Notes:
- With the graphics report, you don’t have to send both reports from both tools, just the one that you currently use (If applicable).
- You can use the option under the reply window to attach the reports and any other files to the thread (Drag and drop here or browse files to attach).
- Our support is only provided in English.
- We may not be able to translate the screenshots attached to the thread.
- To better assist you, we use a translation tool embedded on this Intel Community.
- Can you please provide further information about what are you trying to achieve? please provide as many details as possible.
- How did you confirm that the problem was with our driver?
- Have you tested if the issue persists by using the customized driver from your laptop manufacturer?
- What programs are you using besides the DXVA checker?
I look forward to hearing from you.
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
hi,
Thank you for reply, i've uploaded three attachments as report, please check it.
i just wanna know whether this problem can reproduce by intel official. if yes, please fix it in new drivers; if not, tell me what's wrong here. 🙂
i test not only in dxva checker, but also in many directshow players (mpc-be, potplayer...etc) and they show same problem.
and these players' developers say that's intel driver bug. that's why i came here.
yes, i tried latest lenovo driver and the issue persists.
but i think dxva checker is easy to check, follow my steps and give it a try, i think you can get same result like me.
ps:this issue only happens with direct3d 11 discard mode, everything is ok with direct3d 11 flip mode, more info: https://docs.microsoft.com/en-us/windows/win32/api/dxgi/ne-dxgi-dxgi_swap_effect
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
We will check the information provided, and we will let you know if we were able to replicate it, please be aware of the posts since we might need more information.
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
In order for us to replicate this issue successfully can you please provide the following:
1-A complete list of steps from beginning to end on a .txt file.
2-A video of the process (If possible)
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi
i've made full records and steps, please see the .txt file in attachment.
i think i made it clear now. 😉
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
We appreciate all the information provided, we will attempt to replicate this issue on our end, and we will update the thread as soon as possible.
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Victor,
I found another important clue.
The direct3d11 discard issue appears to be caused by image zooming, at least on my laptop.
When the image is manually downscaled to a very very low resolution, the issue disappears.
I don't know if this is related to my desktop resolution of 2880x1800?
Here is a record i made, you can check it.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
Does this happen with any particular video clip or codec/format? i.e. should we try any video clip? Does it have to be VP8, VP9, HEVC?
The steps provided are very clear but we need this detail to continue with the testing process.
David G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
the issue occurs in this video clip only.
and i tested on nvidia/amd gpus, they work fine
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
Please let us investigate this further and we will reach out as soon as possible.
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi Victor,
Sorry, I made a mistake above. This issue does not only occur in this video clip, many other videos have same problem, H.264, MPEG-2, VP9, HEVC, AV1 VC1... different video formats, different resolutions.
here are some other clips (same issue) for you to test, please check.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello Laraine,
We appreciate the information, and we will use it in our replication process, we will reach out as soon as possible.
Victor G.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello @Laraine
Thank you for taking the time to report this to us.
This has been filed with our driver's development team bug tracking database under bug ID 22012998263. I would like to set the right expectations with you though as this will go under debugging phase first, and if it is determined to be caused by the graphics driver then a fix can be developed. The time it may take to deliver a fix depends on how often the bug occurs, its visibility, overall impact on user experience, business needs, etc.
As soon as there is news or any update on bug ID 22012998263 we'll update this thread.
Ronald M.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hi @Laraine. We're continuing to investigate but we need some additional clarification on the statement below as we continue to look into this issue.
"image broken with direct3d11 discard, fine with direct3d11 flip mode"
Can you please provide clear steps on how to test "flip mode" using DXVA checker, or one of the other applications you provided? It's important that we see the situations in which the issue does not occur.
Thanks!
