23760 Discussions
incompatible driver igdkmd64.sys
DMH681
Edition Windows 10 Home Windows 10 May 2021 Update (21H1) I'm trying to turn on  Core Isolation and I'm getting a message that says  igdkmd64.sys Incompatible and will not turn on.  Is there an update to this and where is it?
DMH681
wlamee
Hello Albert,
I found this thread when trying to enable Memory Integrity on a (relatively old) Lenovo laptop running Win 10 Pro. I have three times 'igdkmd64.sys' (and had an incompatibility with a Western Digital 'wdcsam64.sys', which I managed to remove)
Please let me know where to send my computer specs so you can send me the right file.
Thanks in advance,
wlamee
Alberto_R_Intel
Hi DMH681, Thank you very much for providing that information and the pictures.
just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked in HP's website and the latest Intel® Graphics driver they have available is version 20.19.15.5058 Rev.A, please try a clean installation of that driver following the instructions in the links below:
https://support.hp.com/us-en/drivers/selfservice/swdetails/hp-pavilion-23-q100-all-in-one-desktop-pc-series-touch/8499724/model/8498818/swItemId/ob-219471-2
If the problem persists after that, then we suggest to get in contact directly with HP to confirm if that is the proper driver for your system and also to check if there are Nvidia graphics drivers that need to be installed as well since they are listed on their webpage:
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-23-q100-all-in-one-desktop-pc-series-touch/8499724/model/8498818
Also, we advise to verify with them if the latest BIOS version is currently installed on your system or to gather the instructions o how to install it:
Albert R.
Alberto_R_Intel
Hello DMH681, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
DMH681
Albert R.
Hi Albert,
I have gotten no where with this.  It looks like no one has updated drivers and are not going to update them at anytime.   Really makes no sense to me to have a security feature and not keep the drivers for it updated to use it, or at least update the bios.
The links you provided did not have updates for the intel graphics on this system, but for newer and not the same as mine 4400.
Alberto_R_Intel
Hi DMH681, Thank you very much for letting us know those results.
We are sorry to hear the issue with the drivers persists. Keep in mind that the Intel® graphics drivers are generic, which means they might or might not work with your platform so, when using the Intel® drivers some features and functions advertised by HP will not work properly or will not work at all in your computer.
In this case then, the next thing to do will be to get in contact directly with HP to report the issue and request a new updated driver customized by them for your specific system, they should be able to provide further assistance on this matter, confirm if they will release a new driver for your device of if they already have one and if there is a newer BIOS version available for you to install:
Albert R.
DMH681
Wow I just got off the phone with HP and they are wanting to charge me $50 per month just in order for me to get updated drivers so that I can use a feature they placed as an option in their BIOS settings.. Wow..   Unbelievable...
n_scott_pearson
Sadly, no surprise. These SCUM (HP and Dell both) are relentless. They run their support groups for profit. Imagine!
Dell is actually the worst. Their scam is to have you run this so-called exhaustive hardware test. Then, when (not if) the test finds nothing wrong, they say that it isn't their fault and them investigating any further will cost you money. Yea, right. Their test facility is a scam facilitator and nothing but.
You pay good money for support in your original expenditure and they still want to charge you additional money to actually give you support. If they can't get any additional money out of you, they blame it on Intel and dump you off here. Of course, if this is a system-level or laptop product, you don't even have a warranty from Intel. The processor, the chipset, the LAN and WLAN components, etc. are all covered by the warranty from the vendor, not Intel. Your warranty is exclusively from the vendor. Still, when they dump you here, Intel helps you out to the extend that they can, usually no questions asked (they do draw the line at discontinued products, however). Think about this though: when they sluff you off to Intel with your problem, you are represented by one voice. If HP or Dell come to Intel with a problem, on the other hand, they are representing many thousands of voices. Who's issue do you think gets priority? Not yours, that's for sure! Numbers talk. Bottom line, when the sluff you off, they are actually lowering the priority of your issue significantly!
People complain about Intel support. AFAIAC, Intel has the best support in the business (unfortunately, considering companies like HP and Dell, that isn't saying much). Most people who are complaining about Intel support are complaining because their problem is not fixed instantly. They have no concept of proper software development processes. They have no grasp of the time that is actually required for the full validation of a release. If their problem is one that is truly caused by a software/driver/firmware bug, then it is going to take literally months to be addressed. This is reality.
Off my soapbox now...
DMH681
Yeah, and not only did they want to charge me, but they wanted me to give them full access to remotely take over my pc so they could remotely check/fix any problems it has...   Are ya seriously believing I'm going to hand over my pc... hahahahahaha.. oh yeah, I forgot, I was born yesterday...
RLCarson
I know it's been a couple of years since this was posted but I just recently switched to UEFI.  I ran into exactly the same problem with the same driver while trying to turn on Core Isolation.  I Asked the obvious question on HP Support.  They responded with 100 references, NONE of which addressed the issue.  Apparently they still don't want to be bothered with helping us solve the problem.  I've been all over the internet looking for a way to fix this thing.  Even on the Microsoft site.  Looks like I just won't be turning on Core Isolation.  Makes me wonder why it's even there.  I'm inclined to jump on the "soap box".  I know each one of us is only one out of millions, but also, each of us spend money with these outfits amounting to a great deal in the end.  Seems like they would like to accommodate us just a little tiny bit.  Errrrrrrrgh!!!!!  Thank you, Intel, for the info.  RLC
mr2toyou
I know this is an older post now, but I can across the same issue unable to enable core isolation because of driver igdkmd64.sys.  I used DDU (display drive uninstaller) to purge all display driver files. Once that completed I was able to enable core isolation, perform a restart and re-install UHD 530 drivers and everything is as expected now.  Hopefully this will help someone else searching.
RLCarson
Mr2toyou--Just wanted to say thanks for that response.  Like others, I was frustrated with that issue.  I have a new computer I just got (for Windows 11) and it doesn't have that problem but I'm going to pass the information on with whoever takes my old computer (it's still usable), just in case. 😌  RLCarson
Kai_
I know this topic might be a bit outdated,
but since I was sent here by the almighty algorithm
- and I've had this problem several times after recent Windows 11 updates -
I thought I might be able to assist.
There are ways to remove problematic drivers.
Be careful — there is some risk involved, and you could potentially damage your system.
If you have an OEM###.inf file reference:
You can remove the problematic driver using this command (in a terminal with administrator rights, e.g., PowerShell or Command Prompt):
pnputil /delete-driver oem###.inf
Replace ### with the actual number from your system.
If needed, there's also a forced version
If you do not have an OEM file ID:
You’ll need to find the actual driver file name, then rename or delete it manually.
Some driver file examples I’ve dealt with:
C:\Windows\SysWOW64\Drivers\HWiNFO64A.SYS
C:\Windows\System32\drivers\S332x64.sys
C:\Windows\System32\drivers\igdkmd64.sys
The last file (igdkmd64.sys) was the one causing problems for me.
I’m currently still in the process of getting rid of the yellow warning icon on the Intel HD Graphics 4600.
Even after renaming the driver, I still had to:
  • Remove the graphics card device from Device Manager
  • Restart the system
  • Let Windows reinitialize the device
After that, the system worked — but with the default Intel graphics driver, the onboard graphics card went into problem mode.
Apparently, Intel has forgotten they ever made the Intel HD Graphics 4600. 😅
To be fair, this system wasn’t originally meant to run Windows 11 — so some compatibility issues are to be expected.
So the real question is:
Do you prefer keeping kernel isolation enabled, even if it causes driver conflicts - or would you rather disable it to have a clean Device Manager without warnings or issues?
Best regards
Kai
cverrier
The short answer is that there is no solution to this problem.
igdkmd64.sys hasn't been updated since 2016, and it won't be getting any more updates because it's for a very old discontinued product.
If you want to take advantage of Core Isolation, you're going to need a newer computer.
The final version of this driver is 20.19.15.4531 (Released 29 September 2016).
ChrisBedford
"If you want to take advantage of Core Isolation, you're going to need a newer computer"
Correction: you _may_ need a newer computer
More accurately: you will need to replace the hardware that is raising this error message. In the current case (and I have no idea what type of computer we are talking about here, desktop or notebook) it might be just a case of swapping out the graphics adaptor (or adding one, if it's built in).
Kai_
Use cases might differ.
In my case, I had several all-in-one PCs like the Dell OptiPlex 9030 AIO,
which come with some pretty ancient Intel graphics cards — like the Intel® HD Graphics 4600.
Removing the driver and rebooting allowed me to activate kernel protection!
However, since then, I’ve had an “error message” in the device manager.
Still, the system does display a picture — using the Windows Basic Display Driver.
There might be systems that go completely dark after a reboot.
So far, I haven’t encountered any - but, like always, you really should know what you're doing.
Especially if you need the original graphics driver,
know how to access the system remotely, or how to boot into some “fun” recovery mode. 😉
So yes — it does work.
But...
If you want a clean device manager, and if your system allows it,
you might want to replace the graphics card with a newer one
and disable the historical Intel onboard GPU.
Unfortunately, I’m out of luck here — stuck with an all-in-one system.
Also worth keeping in mind:
it seems these drivers haven’t been updated in ~9 years.
And while I don’t think the cards are officially abandoned,
I wouldn't count on Intel fixing anything soon - or ever.
These systems might still run Windows 11 -  maybe via a server install or some exotic workaround -
but they’re always one Windows patch away from becoming decorative bricks. 😅
cverrier
Intel graphics are pretty much always going to be the on-board ones, so swap out is not going to be an option.  Some motherboards allow the on-board graphics to be disabled, which might allow you to remove the driver.
