22695 Discussions
intel-gpu-tools - register 0xC8254 not available
Username2020
I have Dell Inspiron 3593 with preinstalled Ubuntu. It has very low backlight PWM frequency, probably only 200 Hz (this problem occurs also in different Dell laptops), which is bad for my eyes, so I'm trying to change it. I read that it's possible by installing intel-gpu-tools and running a script which edits the value of 0xC8254 register. However, when I run "sudo intel-reg read 0xC8254", it causes segmentation failure. I've disabled secure boot in BIOS, but it doesn't help. I found out that when I run "sudo intel-reg read" with a different register number, which is described in text files in "registers" folder, it returns some value. Could you please tell me if there's some different register which I can edit to change PWM frequency? Here's the copy of my "registers" folder: https://drive.google.com/drive/folders/1YLDO9I_Fi_ro6_Ib8y092TZFv_sDjfhH?usp=sharing I got no help from Dell support. It's very important, because it makes my new laptop almost unusable.
Best wishes
Sebastian_M_Intel
Hello Username2020,
Thank you for posting on the Intel® communities.
I would like to let you know that Intel does not provide direct downloads and technical support for Linux drivers. The Intel Graphics Linux driver is primarily supported through the Original Equipment Manufacturer (OEM), the Linux distribution vendor, or by the Intel Open Source Technology Center at https://01.org/linuxgraphics
I will highly recommend you to check this inquiry directly with your distro's community: https://ubuntu.com/community
You might find the Linux* Operating System Vendor Websites page useful:
https://www.intel.com/content/www/us/en/support/topics/linux-osv.html
Sebastian M
Intel Customer Support Technician
Sebastian_M_Intel
Hello Username2020,
I hope the previous information was useful to you.
Remember that Intel does not provide technical support for Linux drivers or issues. The Intel Graphics Linux driver is primarily supported through the OEM, the distribution vendor, or the Intel Open Source Technology Center at https://01.org/linuxgraphics.
Based on this behavior it will be better to check it directly with your distro's community: https://ubuntu.com/community
We will proceed to close this inquiry, if you have any questions, please submit a new thread as this one will no longer be monitored.
Sebastian M
Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel or any of its products is implied.*
