22671 Discussions
intel support assistant not working anymore
Taskin501
9 151 Visites
I am using windows 10 home (21H2). Before that, I upgrade to windows 11.  In windows, 11 intel support assistants work correctly I do not face any issue in windows 11. Then I downgrade to windows 10. I do a clean installation. Then starts the problem.
intel support assistant is not working anymore. I make windows 10 clean install 3/4 times but it did not work. I try every method I see on youtube and every method available on Google but it does not work. I try to uninstall and reinstall using (DSAuninstall.exe) over 10/13 times but it does not work.
I try eage, chrome, and firefox without an Ad blocker but it does not work. I use inbuild repair to repair this software 10 times but it does not work. I try every method but I can't fix it.
Now, what should I do now? Please support me to fix the issue.
0 Compliments
27 Réponses
DeividA_Intel
Employé
7 231 Visites
Hello Taskin501,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your
1. Does the tool open or never open?
2. Does the tool get stuck at scanning?
3. If possible, can you take a picture or video where we can see the issue?
4. Please provide the Logs so I can investigate further:
  • Files can be found at C:\ProgramData\Intel\DSA (there will be 3 folders, zip and send all 3 (Data, Downloads, Logs).
5. Run the Intel® System Support Utility (Intel® SSU) to gather more details about the system.
Deivid A.
0 Compliments
Taskin501
7 223 Visites
Ans: Sometimes it opens but the scanner doesn't work and sometimes it never opens.
Ans: Yes.
scanner never work
0 Compliments
DeividA_Intel
Employé
7 217 Visites
Hello Taskin501,
Thanks for the confirmation. Before I proceed to investigate this behavior, please confirm if you already tried the following steps:
1. Check Intel® DSA service:
  1. Ensure both the Intel® DSA Service and Intel® DSA Updater service show the status of Running.
  2. In Windows* Search, type Services and scroll to find Intel® Driver & Support Assistant.
  3. Confirm the Status shows Running; if it isn't running, then start the service if necessary by right-clicking and choosing Start.
  4. Check to see if any Windows* updates are pending.
  5. Restart the system.
2. Clear the browser cache and close the browser.
Thanks for your comprehension.
Deivid A.
0 Compliments
Taskin501
7 211 Visites
I try this but it does not work. I try every single method available on youtube and google. I saw this method on youtube I try it but it does not work.
I try on eage, crome, and firefox without adblocker but it does not work.
0 Compliments
Taskin501
7 198 Visites
Did you find any solution to this problem?
0 Compliments
DeividA_Intel
Employé
7 172 Visites
Hello Taskin501,
Thank you for the information provided
Deivid A.
0 Compliments
DeividA_Intel
Employé
7 164 Visites
Hello Taskin501,
Thanks for your patience. I am still investigating this issue, and to continue further I will need the following:
1. For the logs I will also need the "Data" and "Downloads" folders too.
2. To have a better understanding of this issue, please take a short video where we can see the issue.
Deivid A.
0 Compliments
Taskin501
7 155 Visites
ok I sent you a video
In this location (C:\ProgramData\Intel\DSA) only the log folder is available.
How do I send you a video ?? The video size is more than 71 MB......
0 Compliments
DeividA_Intel
Employé
7 145 Visites
Hello Taskin501,
Thanks for your response. The logs located in "(C:\ProgramData\Intel\DSA)" may be hidden, please check under the tab View>Hidden Items in (C:\ProgramData\Intel\DSA).
Can you zip the video so you can send it in your next response?
Deivid A.
0 Compliments
Taskin501
7 138 Visites
I check the hidden file but no file in there.
I am sending you the video
0 Compliments
DeividA_Intel
Employé
7 110 Visites
Hello Taskin501,
Thanks for the video. I will try to continue with the investigation with the information that you have provided so far. As soon as I have any updates I will let you know.
Deivid A.
0 Compliments
Taskin501
7 079 Visites
Did you find any solution to fix this problem?
0 Compliments
DeividA_Intel
Employé
7 068 Visites
Hello Taskin501,
I am sorry for the delay. We have released a new Intel® Driver & Support Assistant (Intel® DSA) version. In order to continue, use the uninstaller to remove the Intel® Driver & Support Assistant (Intel® DSA) and install the latest version 22.5.34.
Please let me know if the issue persists.
Deivid A.
0 Compliments
Taskin501
7 054 Visites
I try it but I can't fix the issue.
I used your link but it did not work.
0 Compliments
Taskin501
7 035 Visites
I give you the screenshot.
0 Compliments
DeividA_Intel
Employé
7 032 Visites
Hello Taskin501,
Thanks for your confirmation. In order to investigate further, please provide the logs one more time. Remember to also send the "Data" and "Downloads" folders located at C:\ProgramData\Intel\DSA.
Deivid A.
0 Compliments
DeividA_Intel
Employé
6 998 Visites
Hello Taskin501,
After checking your thread, I would like to know if you need further assistance.
If so, please let me know.
Deivid A.
0 Compliments
Taskin501
6 987 Visites
Thank you
I try many ways to fix the issue. Then I notice that the (Data & Download) folder is not created. Then I change the location from drive C to drive E. Then Alhumdullah one issue is solved. Intel support assists now can download the latest driver. But a problem remains the support assist scanner is not working. I try in eage & chrome but the scanner is not working.
how can I send you the (Data & Download) folder? I compress that folder in zipping. But the folder size is more than 71MB.
0 Compliments
DeividA_Intel
Employé
6 933 Visites
Hello Taskin501,
Thanks for your response. I am glad to know that you were able to fix part of the issue. Can you try to zip each folder individually?
If that does not work, are you able to upload the zipped folders to google drive and share the link?
Deivid A.
0 Compliments
Taskin501
6 919 Visites
0 Compliments
Répondre
