23280 Discussions
screen dimms when battery reach 35%~34%
jeffrjbra
Well, im writing because i give up!
cant do anything to solve that, so i need some help!
Just bought a brand new laptop (Gigabyte G5 KD)
its amazing! but there's a problem!
EVERYTIME when my battery reach from 35%~34% the screen dims to zero brightness!
everything is set and ok, battery plans are revised, latest drivers...
THE SAME THING happened with other laptop that was used just to test the same condition
I need some advice!
AlHill
Not an intel problem.  Contact the device manufacturer.
jeffrjbra
You're right!
That's a battery saver "feature" from Gigabyte!
That's horrible!
Thanks for your fast reply!
Stefan3D
Can you make a screenshot from your system control panel?
Did you switch off reducing brightness there?
jeffrjbra
Hey mate!
The problem is solved!
That was a feature in the BIOS of my Laptop!
just disabled and its working fine!
