- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
with rebar ASPM all done..
before i got 19-20watt idle with 60hz 1080p monitor
after rebar ASPM all done
it drop to 7-10watt in 60hz 1080p
if im change 60hz to 100hz for gaming idle back to 19-20 watt
if this normal? or not?
my spek
cpu ryzen 5600G
ram DRR4 32GB
mobo gigabyte b550m ds3H
gpu intel arc b580
psu 850watt gold
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
Thank you for briefly explaining your concern. I understand that you would like to know whether the wattage you are receiving is normal. I will check this internally and get back to you as soon as possible.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
I'm writing to get more information to help you effectively.
1. What is the make and model of the monitor being used?
2. What type of video cable and port is being utilized?
3. What is the current graphics driver version installed?
4. Was everything working fine before, and when did you first notice this issue?
You may also find this article helpful: High Power Consumption when Intel® Arc™ Graphics Card is Idle
I hope to hear from you soon.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
2.port HDMI from monitor viewsonic standar
3. before using driver 32.0.101.6734 (Bersertifikat WHQL) 60hz 7-9watt 100hz 19-20watt
after update driver Intel® Graphics Driver 32.0.101.6737 (Bersertifikat WHQL) still 60hz 7-9watt 100hz more like average 20watt/19watt sometimes jump 30watt
4. everything seems ok following guide from intel rebar, asm etc it drop from ,30watt to 7-6 watt that huge suprise in 60hz but im notice if i rise to 100hz it jump to 20watt
my question is if that was normal thing up 100hz give me 20watt or not?
i know my cpu bottleneck 5600g running of pcie gen 3
it that reason? or is normal because my spec not good for gpu intel? if im upgrade to ryzen 5600x oh higher
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
I appreciate all the information you have provided. I will coordinate with the team to determine if this is normal operation during usage.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
Upon checking, running a monitor at a higher refresh rate increases the demand on the GPU and other system components, leading to higher power consumption. This is why you observe increased idle power usage when switching from 60 Hz to 100 Hz and this is normal.
If you have further questions or concerns, please let me know.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
Thank you for informing me about the situation. Since your account is locked, I sent an email to continue the support. Please check your inbox at your earliest convenience.
Jed G.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello kadudulz,
Jed G.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
