22649 Discussions
window slightly too large for screen - how to make it slightly smaller?
dhewl
No further details. I presume somewhere the window size can be adjusted?
I've no idea how!
Its important as i cannot see things in corners side bottom !
I guess this went wrong in the installation? Not sure though!
Dave.
AlHill
You likely have an overscan issue. I presume you are using some sort of tv monitor? If so, check the display settings on the monitor. For example, on my toshiba monitor there are various settings, where NATURAL is the default, but I need NATIVE.
Doc
Hello xtrick,
Were you able to try the recommendation that was provided by al.hill? In case you still need assistance just let me know.
Fred D.
