Intel® ARC™ Graphics
3294 Discussions
A750 Secondary Monitor won't display 4k w/ latest driver after reboot
pizzapie
I have an Intel A750 which hadn't had any issues until the latest drivers (31.0.101.5522).
It seems to happen after a random amount of time after driver installation (replicated multiple times with DDU + reinstall), which after reboot my secondary display will only show as 1080p even though it display 4k without issue beforehand. When going into display options, it won't allow you to force 4k either.
It's worth nothing the monitor isn't the issue as I've swapped ports etc, it's just whatever isn't the primary display gets affected it seems.
System Information
  • Processor - AMD Ryzen 7 5700x
  • Motherboard - ASUS ROG Strix B550-F Gaming
  • Memory - 16GB DDR4 3200MHz
  • OS - Windows 11 Pro (10.0.22631 Build 22631)
  • PSU - MSI MAG A550BN 550w 80 Plus Bronze
Many thanks
ACarmona_Intel
Hello Pizzapie,
May we know if you have tried to roll back your graphics driver? If yes, does the issue not occur with the previous driver? because if yes, this might be a driver regression.
Furthermore, you may also check out this link for a possible solution to our issue:
We look forward to your response!
Carmona A.
ACarmona_Intel
Hello Pizzapie,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
pizzapie
Hi there,
Apologies about the delayed reply, the suggested solution regarding rolling back the driver seems to have worked.
Hopefully it can be resolved in a future driver update by you guys.
Many thanks,
ACarmona_Intel
Hello Pizzapie,
Thank you so much for the response.
Let's stick with the prior or earlier driver for the time being, and when there is a new release driver, I will let you know so we can try it.
By the way, you're very welcome.
Carmona A.
ACarmona_Intel
Hello Pizzapie,
We have our new release driver, 31.0.101.5534; please try it and let me know the result.
Carmona A.
ACarmona_Intel
Hello Pizzapie,
May we know if you have already tried the driver, 31.0.101.5534? If yes, may we know the result?
We will be waiting for your response!
Carmona A.
ACarmona_Intel
Hello Pizzapie,
We have not heard back from you, so we will close this enquiry now. For additional information, please submit a new question, as this thread will no longer be monitored.
We hope that we have helped you in some way. Bye for now, and have a great day ahead.
Carmona A.
