Intel® ARC™ Graphics
3316 Discussões
A750 performance issues in Snowrunner
Fragmeister
Principiante
13.716 Visualizações
Hello, I recently purchased the a750 and have experienced major performance issues in Snowrunner, max fps I can get is around 50fps and thats with vsync off, when I try to run with vsync on the card defaults to 30fps now matter which in game quality level is selected, now I ran a Firestrike and Timespy benchmark which shows that the a750 is more than capable however I believe that an optimization needs to be done for snowrunner unless you have any other suggestions.
Specs are:
 Win 11 21H2
Ryzen 7 3700X
MSI MAG B550 Tomahawk 7C91vAB bios Pcie Gen 4 and Re Bar enabled and active (verified via Gpuz)
16GB Ram
Arc A750 4091 and beta 4125 Drivers tried
Corsair 850w psu
Snowrunner game purchased and downloaded through Steam.
Tia
14 Respostas
Jean_Intel
Funcionário
13.679 Visualizações
Hello Fragmeister
Thank you for posting on the Intel️® communities. We understand that you are experiencing performance issues with the Snowrunner game.
To further investigate this matter, we would like to have more system information. Please provide us with the reports gathered by the following tools:
  • Provide a video showing the issue behavior and a screenshot of the in-game video settings.
  • Create a report using the following:
    • Intel System Support Utility (Intel SSU)
    • Download the Intel SSU
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Fragmeister
Principiante
13.668 Visualizações
Hello Jean, Thanks for taking the time to take a look at this issue.
 Attached please find the SSU report, the Command center diagnostic, Gpuz which shows rebar enabled and Pcie 4.0, Short video of the issue with FPS in upper right and high video settings shown, no screenshot available in settings mode so is shown in video.
 If you need anything further from me just let me know.
Jean_Intel
Funcionário
13.661 Visualizações
Hello Fragmeister,
We appreciate your response.
Perform a clean installation of the latest beta driver, 31.0.101.4125.  Sometimes corrupted files from previous installations of drivers can linger on a system which can cause driver updates to not work as expected. It is important to mention that BETA releases are for targeted testing.
Also, after reviewing this issue, we noticed that you are running the Windows 11 Build 22000, this is not the latest build version available. We recommend you update your operating system. Here is an article that provides information about how to Update Windows.
Jean O.
Fragmeister
Principiante
13.650 Visualizações
Hello Jean,
 Per your request I updated Windows to 22H2 and attached are updated SSU and Graphic command center diag, also performed a clean install of the 4125 drivers and then tested with zero noticeable difference.
 What I notice is the Gpu usage hovers around 40-50% while Gpu clock is up and down between 700 and 1900Mhz while in game which seems weird.
Jean_Intel
Funcionário
13.595 Visualizações
Hello Fragmeister,
We will proceed to check the issue internally and post back soon with more details.
Jean O.
Fragmeister
Principiante
13.586 Visualizações
Hello Jean, Thanks for the update, I do hope you can get this and the other issues sorted as this is a great product imo, the build quality is far better than that of the red and green teams and the fans are balanced perfectly so very low noise.
 Thanks again and I'll keep an eye out for the next update.
Jean_Intel
Funcionário
13.475 Visualizações
Hello Fragmeister,
Thanks for your patience.
This time we would like to recommend you perform a clean driver installation for our latest production driver 31.0.101.4146.
Jean O.
Jean_Intel
Funcionário
13.431 Visualizações
Hello Fragmeister,
We hope you are doing fine.
Jean O.
f_1111
Novato
13.399 Visualizações
I use a770 16g to run, 1440p Only 30 fps
Not even as good as 1660ti
The drive used is 4146
Jean_Intel
Funcionário
13.376 Visualizações
Hello Fragmeister,
Best regards.
Jean O.
Jean_Intel
Funcionário
Hello ffff_1111,
Please submit a new question on the Intel® ARC™ Graphics community forums, and provide a detailed explanation of the situation to have a more personalized troubleshooting step for your issue. If you'd like, you can try our suggestions from this thread.
Jean O.
Jean_Intel
Funcionário
13.314 Visualizações
Hello ffff_1111,
Before closing this thread, we want to suggest retesting the game using with latest driver, 31.0.101.4255. Once you have tested it and the issue is still present, create a new system report using the Intel System Support Utility (Intel SSU), including third-party tools, and the Intel® Graphics Command Center report again.
Jean O.
Jean_Intel
Funcionário
13.274 Visualizações
Hello ffff_1111,
Jean O.
Jean_Intel
Funcionário
13.135 Visualizações
Hello ffff_1111,
Best regards.
Jean O.
Responder
