链接已复制
I have to agree with you, i was using Arc for the first time trying to figure out why my GPU bottoms out and couldn't figure out why my PC kept crashing. Figured out that Arc was using 100% of memory, then figured out that Arc keeps using memory till it crashes. I wanted to capture the horror (i had to stop the capture before it crashed my PC wasn't sure the capture would save). I will be uninstalling this program.
Update: After uninstalling the display driver, it reinstalled version 31.0.101.4502 which i believe is a roll back of the previous. This seems to have resolved the memory issue for now.
I'm still wondering why I'm NOT having this problem... and why the 4824 Driver and Arc Control Center works fine for me?
Maybe it has something to do with the Windows Version everyone is using?
I'm using Windows 10 Pro and I am NOT experiencing any memory leak issues at all.
It's weird hey? So many people with the same memory leak reported on here, Riddit, Github and videos on youtube... I am very jealous that you are not experiencing the same problem; Perhaps you can assist in showing us what we may being doing wrong, and what you have done right since it thankfully hasn't affected your PC, so that we can fix the issue instead of reporting it to, and bugging, Intel with the problem as they would definitely be too busy to help us?
Are people here using DDU as requested?
Uninstalling and reinstalling is not the same as using DDU.
Uninstalling still leaves remnants/rogue files and folders. DDU will get rid of them.
I was having issues with Arc Control, and my issues were fixed after using DDU.
Are people who are experiencing this problem, using an INTEL version of the GPU?
Or are they using an Acer, Asrock or some other third party manufacturer model?
Intel has often recommended on this forum that if you're using a third party version of the GPU... that you should NOT be using their reference driver/arc software; from their website... but instead that you should download the latest versions available from your GPU Manufacturer's website.
So far...
I've looked at every SSU/IGCC report that has been posted on this thread.
The only common contributing factor that I've seen... so far... is those who are experiencing this issue, are running Windows 11.
While I am running Windows 10, and not experiencing this problem.
If more people who have this problem, could confirm whether they're running Windows 11... well, that alone could be valuable information for Intel to look at; and gives them a place to start looking for a fix.
Hello everyone, @Noval
We appreciate everyone's feedback on this issue. Following several user reports including the ones under this thread we have identified that whenever a Display Adapter other than Intel Display Adapters is installed in the system (e.g. Virtual Display adapters, a second Discrete Graphics card), the Arc Control software will start to incrementally consume RAM (memory leak).
We are at the moment investigating this issue as a top priority to come up with a resolution, in the meantime you can use the following workaround to use the latest driver with an older version of Arc Control:
- Uninstall driver 31.0.101.4824 using DDU
- Install driver 31.0.101.4676 which includes the previous version of Intel Arc Control (1.71).
- Perform a custom installation of driver 31.0.101.4824 unchecking the Arc Control installation option. This will keep the previous version (1.71) of Arc Control. (check attached screenshots)
Hugo O.
We want to let you know we have just released a new driver version 31.0.101.4826 which includes a fix for this memory leak issue, please go ahead and check it out. If the issue still persists after a regular update, please use Display Driver Uninstaller.
Share with us your feedback and let us know if the issue gets resolved from your side.
Hugo O.
I have installed the latest version and it has not been repaired. There is still a memory leak.
Very funny.
Fortunately, I didn't install it, because after reading the update info, they didn't say any about the issue of memory leakage.
