Hello, I have an Arc B580 GPU on a Gigabyte B550 WIFI 6 motherboard. My PC boots fine and the motherboard is using the HDMI cable I plugged into the B580 for the display. The problem is the motherboard only recognizes it as a generic PCIe device, not a GPU. It does not show up in system information at all. When I tried to install the graphics driver manually, I got Error 8, which is along the lines of it cannot detect an intel device to install drivers for. Not sure what I need to tweak in the BIOS or OS to fix this, as I hae never heard of a GPU successfully transmitting display data while not being recognized or used as a GPU by the motherboard. My boot drive is in GPT format as well, which I have heard is needed. Appreciate any ideas or help.
Did you update your bios?
Also, arc requirements:
[This is the dawning of the age of Colossus, where peace is compulsory, freedom is forbidden, and man’s greatest achievement is man’s greatest mistake.]
