Intel® ARC™ Graphics
3297 Discusiones
ArcB580在游玩Honkai:Star Rail时出现问题
糕渐离
Principiante
1.923 Vistas
ArcB580在游玩Honkai:Star Rail时经常无故画面卡死导致电脑直接重启,同时音频也卡死蜂鸣直至电脑关闭
我的硬件配置为:CPU:5700x3D
                                 RAM:Crucial DDR4 3200Mhz 16G   x2
                                 GPU:Gunnir B580 Index
                                  Windows 10 专业版  22h2(19045.5608)
0 kudos
18 Respuestas
Mike_Intel
Moderador
1.878 Vistas
Hello 糕渐离,
请注意,我只能用英语为您提供支持。我使用网络翻译工具翻译了此回复,因此翻译可能有些不准确。
  1. When did you start using your Arc B580?
  2. Are you using an Intel brand Arc B580?
  3. Can you provide the specification of your power supply?
  4. What is your game launcher?
  5. What are the troubleshooting steps that you tried so far?
Michael L.
糕渐离
Principiante
1.852 Vistas
1.大概从2025.2开始使用
2.我使用的Arc B580来自于Gunnir,具体型号是Index
3.我使用的电源为500W
4.我直接把游戏程序固定在任务栏,没使用任何启动器
5.我尝试过关闭‘可调整的BAR’功能且疑似有效,但我仅仅尝试过一次
   关闭XMP无效,更换Windows系统版本无效,更换驱动程序版本无效
补充:我在其他Arc B580用户那里听到了与我一模一样的情况,且目前没有任何办法解决,但疑似Intel CPU与Arc B580搭配没有此类情况,因为出问题的用户几乎都使用AMD CPU
Mike_Intel
Moderador
1.824 Vistas
Hello 糕渐离,
Thank you for the update.
Let me ask some questions or comment on the information that you just provided.
  1. Can you tell us where did you download this game? Or please share the link.
  2. Intel Arc Graphics require 600 W power supply or higher. Please refer to this link for that information: https://www.intel.com/content/www/us/en/support/articles/000091128/graphics/intel-arc-dedicated-graphics-family.html
  3. Can you share videos of the issue?
  4. Can you help generate the SSU logs of your system. Please refer to the link below on how to generate the logs:
Michael L.
糕渐离
Principiante
1.764 Vistas
您好,我在《崩坏:星穹铁道》官方网站——愿此行,终抵群星下载游戏且游玩
很遗憾,我并没有多余的资金额外购买一台额定600瓦及以上的电源
糕渐离
Principiante
1.752 Vistas
文件较大,因此我做了加速处理,请谅解
Mike_Intel
Moderador
1.783 Vistas
Hello 糕渐离,
Michael L.
Mike_Intel
Moderador
1.712 Vistas
Hello 糕渐离,
I understand that you cannot buy a 600 W power supply at the moment however please also understand that this a possible reason of the issue.
Upon checking the SSU, I also found out that you are using driver version 32.0.101.6651.
The latest that we have is Driver 32.0.101.6734
So please update the driver using DDU method. Please refer to the links below for the latest driver and guide for DDU.
https://www.intel.com/content/www/us/en/download/785597/intel-arc-iris-xe-graphics-windows.html
https://www.intel.com/content/www/us/en/support/articles/000091878/graphics.html
Michael L.
糕渐离
Principiante
1.626 Vistas
感谢解答,我使用ddu更新驱动至6734之后仍然有此类问题。另外,6734对游戏性能几乎没有优化,但CPU和GPU占用率升高了很多,我不得不退回6551
Mike_Intel
Moderador
1.645 Vistas
Hello 糕渐离,
Michael L.
QyInvoLing
Principiante
1.617 Vistas
This problem still exists everywhere. The solution I found is switching PCIe to 3.0 in BIOS.
Being provided such solution, can Intel do something to find the root cause and fix it in the driver? If it's related to PCIe link speed then the game producer would have nothing to do with the problem
QyInvoLing
Principiante
1.617 Vistas
这个问题的解决方案是,在bios中将PCIe速率调整至3.0
The solution is switching PCIe link speed to 3.0 in BIOS.
糕渐离
Principiante
1.561 Vistas
Mike_Intel
Moderador
1.582 Vistas
Hello 糕渐离,
To further investigate this issue, please help provide the following details.
  1. Can you send some screenshots or videos of the issue?
  2. Are you using Steam or Epic Games to launch the game?
  3. If no, where did you download the game?
  4. Please help generate the SSU logs of your system. Kindly refer to the link below on where to get those markings
@QyInvoLing
If you need assistance, please create a new thread for us to assist you on your own thread and gather the details of your systems.
Michael L.
糕渐离
Principiante
1.563 Vistas
您需要的一切信息我已在之前的回复中提供,麻烦您翻阅
Mike_Intel
Moderador
1.509 Vistas
Hello 糕渐离,
I am sorry if I did not explain why I am asking for another set of SSU.
The SSU that you provided before , the Graphics driver is not yet updated. That is why I am asking for another one that shows that the drivers are updated because this is the bases of your deep investigation of this issue and we might try this in our lab.
Michael L.
WEmwuZ
Principiante
1.489 Vistas
I can also provide information on this issue, which seems to be a common problem on Hokai:Star Rail.
My GPU: Maxsun Arc B580 Index
Driver Version:32.0.101.6734 WHQL Certified
Mike_Intel
Moderador
1.379 Vistas
Hello 糕渐离,
@WEmwuZ
Michael L.
Mike_Intel
Moderador
1.341 Vistas
Hello 糕渐离,
I am sending another follow up on the information that I requested.
Michael L.
Responder
