Intel® ARC™ Graphics
3302 Discussions
B580 Stuttering in Dual Monitor Setup
Radbod
if i Play BO6 on one Monitor and YT Videos in Edge on the other, Frames Stutter and drop to 60fps or less
CPU is at 70-100% then. If i close edge and terminate all processes with the taskmanager, frames go back to normal.
SSU attached!
JedG_Intel
Hi Radbod,
I understand that you are experiencing stuttering whenever you play games and watch videos on the second monitor. Please assist with the below information so I can address this correctly.
1. When you say BO6, do you mean Black Ops 6?
2. Is the issue isolated to this game?
3. Have you enabled hardware acceleration on Edge?
4. Does the issue happen with other browsers?
5. What in game settings are you using?
I also can't seem to open the SSU file that you attached. Please generate another SSU report for me to check your system components and configuration.
Jed G.
JedG_Intel
Hello Radbod,
Jed G.
JedG_Intel
Hello Radbod,
Jed G.
