Intel® ARC™ Graphics
3288 Discussions
Batman Arkham knight 2 FPS and no video card problem
Furkann
(sorry for using translation)
Hello, my problem is that in the game "Batman Arkham Knight", the game does not see the video card. It sees it as Microsoft basic.
Before that, the game would not open at all, no error. I solved that problem with difficulty, but I can't solve this one.
I'm using the latest arc driver. Another friend said that he had the same problem with the same game before, but you didn't find a solution.
Furkann
Andres_Intel
Hello Furkann,
Thank you for posting on the Intel communities. I see that you are having low-performance issues with your Intel® Graphics Card, I will be happy to help you.
To have a better understanding of the situation, please answer the following questions:
Andres P.
AjrAlves
New Contributor II
Seems like the game is running on CPU render, in that case, it could be:
1- No drivers installed and/or corrupted drivers (uninstall any GPU drivers with DDU and download latest drivers from intel website)
2- If dedicated GPU, It could be PCI express bad contact, try reseating the GPU
3- Resizable bar disabled and/or old motherboard BIOS, should update it to the latest stable version.
Intel Arc/Xe Drivers: https://www.intel.com/content/www/us/en/products/docs/discrete-gpus/arc/software/drivers.html
DDU: https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
Random DDU tutorial: https://www.youtube.com/watch?v=bP-2B14Nckw&ab_channel=SantiagoSantiago
Andres_Intel
Hello Furkann,
Were you able to run Intel®SSU?
Andres P.
Andres_Intel
Hello Furkann,
Andres P.
Furkann
I fixed the problem by installing dxvk, thank you for your attention.
